Spindle Mod for 1LE question for the gurus??????
Old Dec 12, 2002 | 07:59 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
OK guys....I now have like 95% of the parts needed for a 1LE conversion, and already modified the spindles. I have a question though, while trial fitting the parts, I noticed that the two holes drilled to mount the carrier bracket adapter aren't exactly lined up in the same plane. Meaning, that when you attach the bracket, the bracket does not sit perpendicular to the spindle(one side is higher than the other). The difference between the two surfaces is about 1/16", so its not immediately obvious. The spindles I believe are from an 84 or 85 Z. Are there differences in the earlier spindles VS later models that will require further machining, or spacers? From what I can tell, I will have to machine down the lower hole surface(not the one near the strut) to compensate for the difference, which makes the caliper carrier sit only about 1/16" of an inch away from the front side of the rotor. Can anyone shed some light on this? Many thanks in advance.....:hail:
Old Dec 12, 2002 | 08:09 PM
Sunoco#6's Avatar
Could you shim it?...using shims is a common techique with some caliper alignments (ie safe). Maybe you could use a machined washer like a thrust washer, thats how the Performance Machine brakes on my YZFR1 was aligned (floating disks).
Good luck.
Old Dec 13, 2002 | 07:33 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
WOW that's odd...I'd just put a "shim" or washer in there to even it up. You'll be fine.
Ed
Old Dec 13, 2002 | 08:57 AM
jwscab's Avatar
Engine: Many
OK, thats kind of what I was thinking, but then the bracket adapter wounldn't be sitting directly on the spindle on the upper mounting point(near the strut). Wasn't sure if that would be acceptable to have a shim in there. Does anyone have a picture of the caliper carrier and the rotor without the caliper installed, so I can see the distance between the outer surface of the rotor and the carrier? Or can someone let me know about how much distance they have there? Again, thanks for the replies. It just figures that I have a weird issue like this....
Old Dec 13, 2002 | 03:16 PM
ebmiller88's Avatar
I had no such problem...all of my pics are in the link in my sig.
Ed
Old Dec 14, 2002 | 03:14 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
jwscab, Do you have a copy of my CD? If you do not, it has all the 1LE conversion pistures you could ever possibly want.
I would suggest not using any shims at all. 1/16" (.060") is nothing to worry about. Do another trial fit with the adapter bracket installed backwards (flat side toward the spindle). You will then notice that the adapter bracket will tend to rock slightly on the lower mounting boss.
Thanx,ANDYZ28
Old Dec 14, 2002 | 10:03 PM
jwscab's Avatar
Engine: Many
Andy, thanks for the info, The CD is on my list of things to get......at this point, I was doing some trial fitting, and noticed this, and wanted throw it out there in case anyone ever saw it before.....just seemed a little weird....one more quick question, what are people doing for rear 89-up caliper mounting plates for 9 bolt set-ups?
Old Dec 15, 2002 | 08:48 AM
ANDYZ28's Avatar
Car: 1982 Z-28
As far as I know, I am the only one who has these 9 bolt backing plates at a reasonable price NEW.
Thanx,ANDYZ28
Old Dec 15, 2002 | 03:21 PM
jwscab's Avatar
Engine: Many
Will they be available from your website? I didn't see them listed anywhere. And what will be the damage for a pair($$)? Thanks
Joe
Old Dec 15, 2002 | 04:55 PM
ANDYZ28's Avatar
Car: 1982 Z-28
They are not avilable through the website. I only have a limitied supply @ $70.00 per pair. They will fit 9 bolt or 10 bolt rears. Those of you converting your 10 bolt to the PBR ( '89 and later) style rear disc brakes will require an adapter and shim set to use these backing plates. I have these also if you need them.
It is my intention to offer these item to thirdgen.org members only, and to avoid any "commercial" sales.
If anyone is interested? Please let me know by the end of the month. After that I will be turning the entire brake oreration over to another company, and the price can only go up. The door hinge thing has taken up all of my time. As I now cover nearly all GM trucks now too.
Thanx,ANDYZ28
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
redmaroz
Aug 16, 2015 11:40 PM
