lowering my car but?????
Old Dec 18, 2002 | 08:32 PM
Xceleratemaro's Avatar
i am going to install a 355 in my car in a month but i will use v8 spring off of a iroc z i want to cut these so it will lower about an inch > only in the front> now the problem is i will also have shorty hedders and have air shocks in the rear and i want to run Duel exhaust with flowmaster and dumps right at the rear end. now will this work or will my exhaust scrape
please give me your thoughts.
thanks
Old Dec 20, 2002 | 07:59 AM
MdFormula350's Avatar
the ones from the iroc-z might be wore out already thus the car might be lowered already..
Old Dec 22, 2002 | 11:55 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
hehehe u said "*****" hehehe
Old Dec 23, 2002 | 05:25 AM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I have long tube headers and dual exhaust ending with two 1 chamber flowmasters before the rear axle.My car is dropped about 2",and with 275 40 17 tires. The lowest point on my car is about 1 7/16" off the ground with no one in the car.That is the bottom of my headers. But with shorty headers and only a 1" drop,you should have a lot more clearance than me.
Old Dec 26, 2002 | 07:52 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Any pics RS would like to see dual exhaust??
Old Dec 26, 2002 | 09:23 PM
Z28DJP1987's Avatar
OK, if you like the sound of metal screaming from under the car.
Old Dec 26, 2002 | 10:54 PM
AFreaknGoodTme's Avatar
If you could have seen the speed bump that I shredded with my Spohn torque arm solid front mount. It sits about 3 1/2" off the ground. If I ran duals I gaurantee they would not last a day.
Old Dec 27, 2002 | 07:29 AM
Z28DJP1987's Avatar
With that car's ride height, I can hear that metal screaming now. One question why so low, it serves no purpose except to look like a ---------(insert own discription)????
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
