clunk from front end
Old Dec 29, 2002 | 03:54 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
My camaro has a clunk whenever I hit a bump with the pass side front It has new ball joints and new struts, any suggestions on what it is?
Old Dec 29, 2002 | 07:31 PM
PonchoTA's Avatar
Loose tie rods? Was everything torqued correctly, and cotter pins installed in the right places?
Old Dec 29, 2002 | 07:39 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Sounds like your outer brake pad is loose in the caliper....and rattling whenever it gets jolted (bumped). Try lightly applying the brakes when you go over a bump or something similiar....if the noise disappears, that's the cause of it. You can use a large pair of waterpump (aka slipjoint) pliers to tighten the 'ears' of the pad onto the caliper, or get a tube of 'Disc Brake Quiet' and apply a bit to the backside of the pad where it contacts the caliper.
Pete
Old Dec 29, 2002 | 08:02 PM
Engine: 383
the pads aren't loose, the noise sounds deeper than that, if there's a passenger in the car they can feel it in the floor.
Old Dec 29, 2002 | 11:01 PM
Sway bar mounts and end links?
Old Dec 29, 2002 | 11:52 PM
MdFormula350's Avatar
check for anything else lose or worn out.. like bushings, etc..
Old Dec 30, 2002 | 11:39 AM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
It sounds like it might be the tranny mount.
Old Dec 30, 2002 | 11:43 AM
Engine: 383
nothing stands out as loose and I have an energy suspension tranny mount(got tiard of replacing those POS rubber ones-it sounds nothing like a tranny mount)
Old Dec 30, 2002 | 10:37 PM
justadba's Avatar
Car: 88 IROC convertible, 88 Sport Convertible---both RED
Engine: 350 TPI in the IROC, 305 TBI in the Sport
Transmission: 700R4 in both
'88 vert did the same until I changed the front brakes...mine was the caliper was sticking and clunked when it "broke" free
changed the rotors, pads and calipers and problem went away
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
