Wonderbar not compatible on 82 models?
Old Jan 17, 2003 | 01:17 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
looking around for a wonderbar, i noticed on spohn's site there was a note stating the piece would not be compatible with an 82 f-body.
No other site that sells these have this disclaimer.
What exactly is the fitment issue with the spohn wonderbar?
Old Jan 17, 2003 | 01:29 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i didn't think that ANY wonderbar fit on 82's something to do with the 82 body not having the same location for mounting holes.
Old Jan 17, 2003 | 01:36 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I think LONSAL has wonderbars for the '82 model.
www.top-downsolutions.com
Old Jan 17, 2003 | 01:45 PM
Car: 82 Trans am
Thanks, Js. I checked top down solutions, and it looks like the 83-92 is on backorder until the end of february, but I couldnt find anything about an 82 wonderbar.
How hard would it be to use the sway bar bushings as a guide and make my own wonderbar? My brother is a fairly competent welder, and it looks like it shouldnt be too hard to make. It looks like just the 2 brackets connected with a piece of tubing.
Any suggestions on mocking something like this up?
Old Jan 17, 2003 | 01:55 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Measure twice, cut once
Old Jan 17, 2003 | 03:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How about
Measure with a micrometer, mark with chalk, cut with dynamite
Old Jan 17, 2003 | 07:31 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Thanks, Js. I checked top down solutions, and it looks like the 83-92 is on backorder until the end of february, but I couldnt find anything about an 82 wonderbar. Any suggestions on mocking something like this up?
'82 has the mounting holes loctaed differently than the '83-'92 cars.
When Top-Down resumes production of wonderbars, they will be redesigned so they fit the '82 models.
Old Jan 17, 2003 | 09:07 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I can answer. The GM Wonder bar (or aftermarket ones) that are designed to fit the offset bolt pattern used on the 1983-92 F-Bodies won't fit some 1982 F-Bodies. Early 1982 F-Bodies had a straight bolt pattern to mount their sway bar retaining brackets. You can compare the pictures of my 205170 (1982) greasable sway bar bushings to the 200170 (1983-92) greasable sway bar bushings on my web site. I've discovered that the change was made as a running change some time in the 1982 model year. I don't yet have a vin number that the change was made. The best way to know if it will fit is to lift your car and take a look at what you have. And yes my new version has been re-designed to accomodate either model.
Lon
Old Jan 17, 2003 | 09:47 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I have a GM wonderbar on my '82. As well as the 1LE front swaybar. It fit just fine with no modifications.
Thanx,andyZ28
Old Jan 17, 2003 | 09:58 PM
lonsal's Avatar
Ah, but Andy what is the bolt pattern on your sway bars retaining brackets? Early ones had a straight bolt pattern that won't work for the Wonderbar. Some 1982 have the newer offset bolt pattern. The sway bar doesn't matter. It will fit in either style of bracket, since both brackets will accomodate the same bushing. I've even seen a few 82's that GM re-drilled the old 14019271 brackets so they would work with the new offset bolt pattern.
Lon
Old Jan 18, 2003 | 07:01 AM
ANDYZ28's Avatar
Car: 1982 Z-28
I believe I have the "offset" bolt hole pattern.
Thanx,andyZ28
Old Jan 18, 2003 | 08:44 AM
kevinc's Avatar
Car: 1982 Z28
Thanx,andyZ28
Another '82 here with a GM wonderbar, no problems or mods during installation. I'm running a 36mm WS6 front swaybar and Global West bushings, again no mods or issues installing.
Old Jan 18, 2003 | 09:39 AM
Car: 82 Trans am
my vin has the build number 511721, if i'm not mistaken this is sequential with the order the cars are built.
anyone with an offset mounting (later style) 82 fbody, what is your vin?
Old Jan 18, 2003 | 04:39 PM
ANDYZ28's Avatar
Car: 1982 Z-28
CN136332 w/offset bolt holes
Thanx,andyZ28
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
tmellott89
Oct 14, 2015 02:06 PM
Briandrex
Oct 5, 2015 06:20 AM
paul_huryk
Oct 1, 2015 04:27 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
