rear rotor help
Old Feb 2, 2003 | 01:35 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
rear rotor help
i'm in the process of replacing the rear rotors on my IROC...
apparently the rotors have rusted themselves to the axle... does anybody have any tips on how to remove them?
thx for the help
Old Feb 2, 2003 | 01:48 PM
MdFormula350's Avatar
never had that happen before, maybe try some type of spray lubricant... maybe a few light taps from a hammer also..
Old Feb 2, 2003 | 01:53 PM
prockbp's Avatar
Car: 1989 IROC-Z
thx for the response... i tried some WD40 and a mini sledge hammer... hehe but it's not coming off yet
keep those suggestions coming
Old Feb 2, 2003 | 03:21 PM
prockbp's Avatar
Car: 1989 IROC-Z
ouch...
i went and bougt some penetrating fluid and let it soak on all the corrosion for about an hour or so... then i got my 3lb hammer out again and gave the rotor about 3 light hits from the backside and apparently i broke the c-clip because my axle came out of the rear end..
hehe... gotta hate that....
figured i would post this up here so that if anybody else ever has this problem they'll know what not to do....
Old Feb 2, 2003 | 03:46 PM
prockbp's Avatar
Car: 1989 IROC-Z
this is getting crazy... i removed the wheel studs and and the rotor is still holding onto the axle with some kind of death grip..
my final effort will be to spray some penetrating fluid into the holes where the studs used to be and leave it overnight....
if that doesn't work then i guess i'm going to have to buy some new axles..
how much are new axles anyway?
Old Feb 2, 2003 | 05:52 PM
Morley's Avatar
The place it is most likely rusted fast is at the center hub. The place where the rotor slips over the center is a pretty tight fit without the rust. Spray the whole rotor down with the WD-40 and let it sit over night, then hit it on the edges with a hammer in several places and see if it loosens up. Hopefully you only broke the "C" clip and not the end of the axle because you're going to need to anchor that axle somehow to work that rotor off, so before you go too far, check the axle, if the splined end broke off...chuck it in the garbage and move on.
Old Feb 2, 2003 | 08:52 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
AIR HAMMER. get an air hammer. It 'll do the job with a lot less damage to other parts. That is how brake shops do it. Hope I told you in time. Nothing like getting p****d at your car with a sledge hammer in hand. Bad things man--bad things.
Old Feb 3, 2003 | 07:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
C-clips almost never break; it's almost always the axle.
Pull the axle out and look at it. If the end of it is broken off, problem solved.... you need an axle and a caliper.
Old Feb 3, 2003 | 09:13 PM
prockbp's Avatar
Car: 1989 IROC-Z
i would like to thank StreetRCR for enlightening me... because $230 later(air compressor and an air hammer) i got the damn rotors off... and will also get a load of use out of my new pneumatic tools
thanks for the insight RB83L69.. i believe that i found the problem with the axle... and the fix was very easy.... embarrassingly easy..
but you're input sets me at ease because i thought i might have messed something up
Old Feb 4, 2003 | 05:23 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
Glad I could help! I've been there and it wasn't pretty
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
