spohn wonderbar
Old Feb 25, 2003 | 05:11 PM
jbcmyk's Avatar
spohn wonderbar
i purchased a spohn wonderbar and it does not fit.
it has a slight bow in it, and i can get 1 side on however the other side is about 1/4 in out of alignment.
i have it positioned correctly.
has anyone else had trouble? or is there a special trick due to the bow in order to tighten everything?
thanks
john
Old Feb 25, 2003 | 07:37 PM
92GTA's Avatar
Mine did not have the bow in it but the holes did not line up. Just grind the holes out so they fit...
Old Feb 25, 2003 | 08:48 PM
87transam5.7tpi's Avatar
I just made my own wonder bar out of 1.5 in tubing. it was VERY VERY easy to do, I'd suggest to anybody to make there own if possible. it cost me like $5 to make.
Josh
Old Feb 25, 2003 | 09:21 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
[QUOTE]87transam5.7tpi I just made my own wonder bar out of 1.5 in tubing. it was VERY VERY easy to do, I'd suggest to anybody to make there own if possible. it cost me like $5 to make.
Josh [QUOTE]
Do you have any pics you could share? What is and where does a "wonderbar" go?
Old Feb 25, 2003 | 09:23 PM
I don't have any pictures right now, but go to spohns site and they have a picture of one installed. they go in between where the swaybar mounts to strengthen the front of the frame. Great mod for the money!!
Old Feb 25, 2003 | 09:29 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Hey thanks for the idea. At the Spohn site they have an installed pic. Now I know what you mean when you say it is a great mod for the money. Last year I had to weld my frame where it began to crack around the steering gear box.
Old Feb 25, 2003 | 09:34 PM
ya even if you can't make one yourself they are worth the $60 IMO.
Josh
Old Feb 25, 2003 | 09:42 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Oh, I have made almost all of my chassis and frame parts so far so I think a "wonder bar" should not be to bad. I made my own SFC, STB, adj. panhard, 6 pt cage, and LCAs. I did however buy the Spohn torque arm/crossmember when I changed over to a TH-350.
Old Feb 25, 2003 | 09:45 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
easy replica
Josh, i saw the spoon wonderbar,
you have used 1.5" tube, must be better than spohn,
they use 1.25" x .120". or maybe 1.25 if enough?
Still i'd like to see yours, I guess there Exactly like spohn, it's so a simple desing, can't go wrong.
so it bolt between the torsionbar bracket and the "frame" of the car... is that right?
Old Feb 25, 2003 | 09:59 PM
thats exactly what mine looks like, but its black and I didn't take time to fire up my powder coating machine so its chiped and stuff :-(
Old Feb 26, 2003 | 08:19 AM
jbcmyk's Avatar
spohn wonderbar
by grinding the holes larger, wouldn't that defeat the purpose?
then there would be play in it?
john
Old Feb 26, 2003 | 12:03 PM
92GTA's Avatar
Not if you use a welder to make the hole smaller again
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
snakeshooter
Sep 10, 2015 07:46 AM
