Max tire size on stock RS 15 inch rims
Old Mar 9, 2003 | 09:07 PM
2000_Eclipse_GT's Avatar
Max tire size on Stock 15 inch RS wheels???
These 215/65/15's are just too narrower...
It seems if you go above 225 series you cant get any good speed ratings on the tires... all T's and S's.. I want H or higher as I actually like to corner some and that comes with the higher speed rated tires!
Old Mar 10, 2003 | 06:40 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I have 225/60's in the front and 235/60's in the rear, you can fit up to a 275 on the rear but i wouldn't . I would go 265 or 255 max.
Old Mar 10, 2003 | 11:21 PM
bes217's Avatar
I put 235/60/15's on mine and they are great. They are the Yokohama Avid S/T. I am not sure of the speed rating of them though. I got them from tirerack.com. Summit sells them also. I saw them in their magazing and I think on the 15 inch rims you can fit up to 255 on the 7 inch wide rims. I don't know what speed rating but the max for your 15X7's is 255.
Old Mar 11, 2003 | 12:49 AM
OK cool... well I dont like any of the speed ratings on the 245/60/15's so I will prolly drop down to 245/50/15's which gets me into a much more expensive tire but a much better one... Thanks for the help guys!
Old Mar 12, 2003 | 08:41 PM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
235/60R15 on the front. 255/60R15 on the rear. No rubbing at all
Old Mar 12, 2003 | 09:40 PM
hahaha with the 255's out back maybe I should run a truck tire... since the only one tirerack has in a 255/60/15 with a decent speed rating is a truck tire...
Old Mar 15, 2003 | 02:07 AM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
need some enough
not exaclty sure what 2 first numbers in tire size stand for
right now i have 215/65/15 michelins
i know the last one is rim size, but what do the first 2 mean?
im looking at some 215/40/15 SZ 50 firehawks
z-rated.....
Old Mar 15, 2003 | 03:11 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
In some cases truck tires are better(if the profile is high). They have a stronger/stiffer sidewall. At my local track(for stock enduro class) we have to run 70 or 75 series tires all around so a truck tire is the only option and some of them actually stand up pretty well.
Old Mar 15, 2003 | 11:15 PM
the truck size was 255/60/15 I believe....
215= width
65 is an aspect ratio of the width of the tire
15 is the rim size
So I wanted to go 245/50/15's to stay closer to the stock 215/65/15 size so I would not throw off my speedometer....
Old Mar 16, 2003 | 04:05 PM
Marc 85Z28's Avatar
FYI the 245/50r15 are a 25" tire, while the speedo is calibrated for a 26" tire... I had those on the front of my car for a while and with it not being lowered it looked funny - too much gap between the fender and tire. 235/60r15 is good size.
BFGoodrich makes a 255/60r15 tire in the Radial T/A. That tire is well known for being a popular muscle car tire.
Old Mar 17, 2003 | 07:21 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i have a set of 245/60/r15 goodyear eagles on a set of 15x7 rims on my sport coupe.
Old Mar 17, 2003 | 08:41 PM
Engine: 3.1
o so i wanna do somethin like 235/60/15's front and 255/60/15's rear??
with these kick *** tyres i found
f
Old Mar 19, 2003 | 10:58 AM
Marc 85Z28's Avatar
krazycracka55 - I had 235/60r15 on the front and 255/60r15 on the back several years ago with no problems whatsoever. It did slightly increase the rake of the car by lifting the rear just under 1/2". It only threw my speedo off a little bit, I was doing 62 with the speedo reading 60.
Old Mar 19, 2003 | 04:42 PM
Eternal's Avatar
4MULA88; I know this if a goofy question but what if i ran the tire size you had with a backspacing of 4" ? is there any reason to think thats they will stick out to far and rub on the fenders?
Old Mar 19, 2003 | 06:34 PM
Engine: 3.1
well i went and got the pricing for Firehawk SZ50 EP's n 245/60/r15's all the way round and ya with them being 198$ a peice im gettin the tires, installed, balanced and road hazard all for 650$
u like how that sheot works!
Old Mar 19, 2003 | 06:38 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
nice buy. You'll be huggin the road large with those in the wet and dry. Never heard a bad thing about them.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
Exxon Limited
Aug 9, 2015 08:13 PM
