Drum to Disc
Old Apr 11, 2003 | 02:02 PM
JayRocZ's Avatar
Drum to Disc
What do i need to swap my 88' drum rear end for a 9 bolt posi disc rear from 87-89 iroc? any special kits?
Old Apr 12, 2003 | 10:20 AM
Spdfrk1990's Avatar
i would just buy an iroc rear end from the junk yard and swap em.
Old Apr 12, 2003 | 10:27 AM
JayRocZ's Avatar
thats what im getting im just wondering if it will just swap it cause i have drum brakes in mine now and im getting a posi disc from another iroc to put in im just wondering if i need anything like brake lines or anything for the braking system or will it just bolt right in
Old Apr 12, 2003 | 10:29 AM
Spdfrk1990's Avatar
No it will bolt right in i think the e-brake cables r different tho. You might want to change ur proportioning valve tho.
Old Apr 12, 2003 | 11:42 AM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Also-
with the prop valve- watch out becuase the thread pitch on some is different than on others- I found out the hard way.......
just a heads up
Old Apr 12, 2003 | 12:35 PM
oOSpeedFreakOo's Avatar
iroc rear end
is the 88 iroc rearend any stronger looking for somthing to put the power to the ground behiond a 383 punched .060 over that i wont blow up on the quarter mile???
Old Apr 12, 2003 | 02:27 PM
Car: 1991 RS
Well, neither the 9 nor 10 bolts are much to write home about when you have a 383 in the car and plan to drag it.
They can be strengthened (sp?) to a degree and would probably last with mild street abuse, but if you are doing red-line clutch dumps every other weekend, I'd just as well go with a 12-bolt (or Ford 9") right from the start.
The 9" Fords are pretty nice- I was talking with a guy that could provide me with the the unit made to proper length with proper mounts and spring perches and also weld the chevy type flanges on the end so I could still use my current Baer disc setup. These tend to cost a few dollars, though.
However, an upgrade investment now might save time and money down the road.
Like always, it depends on current funds and future plans-
Best-
S-D
Old Apr 15, 2003 | 11:21 AM
jawzforlife1's Avatar
You will need disc brake e-brake cables and proportioning valve.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
