Brake Line Flaring
Old Apr 27, 2003 | 06:57 PM
CamaroMike's Avatar
Brake Line Flaring
I just installed my Bear Adjustable Prop Valve, and boy was it a mother. I had to go to four auto parts stores to get the right adaptors to plumb the front circuit of the master cyl to the front two brake lines and I could not find any adaptors for the rear circuit. The Prop Valve instructions said to cut the lines, slide on the new fittings and "flare" the lines. I could not get two different flaring tools to make a double flare so I settled for a single flare. I was just wondering if a single flare is enough to keep the lines sealed? Any input would be greatly appreciated!
Old Apr 28, 2003 | 08:27 PM
Rage13's Avatar
Car: 89 Firebird
what do you mean by "double flare"?
Old Apr 28, 2003 | 09:26 PM
CamaroMike's Avatar
Folding the line on itself before making the tapered seat. All prefabed brake lines are "double flared".
Old Apr 29, 2003 | 05:41 AM
ede's Avatar
ede
single flare won't hold up under preasure, that's why the lines are double flared. my double flare kit is made by snap on and works every time.
Old Apr 29, 2003 | 07:02 AM
melamkish's Avatar
If you buy a flaring tool, make sure it is designed for steel line. Some that are sold are made for flaring soft tubing like copper and just won't work on steel tubing.
Old Apr 29, 2003 | 07:55 PM
CamaroMike's Avatar
I said to hell with the flaring and just fabbed up all new lines to the rear. I know the prefabbed stuff is way better than anyone could make with a flaring tool. Ede, I will have to look into a Snap-On, Matco, Mac, flaring tool. The ones I tried were KD and Craftsman, both poopie.
Thanks for the help, Mike
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
