Eibach Drag Launch Spring Kit vs. Pro-Kit?
Old May 16, 2003 | 06:14 PM
MdFormula350's Avatar
Ok i ran some searches on both sets of springs and wanted to get some more opinion on whats everyone running and how they perform on the street and strip.
Heres my setup:
Lakewood drag shocks and struts, 70/30 front and 50/50 rear
Spohn sfc's, relocation brackets, torque arm, panhard bar, lca's.
I akready have a pro-kit in my garage and but after i found that Eibach made a drag launch set i was wondering how good they would be on the streets, i know they work very nice at the track.
Like any comments on any possible lowering, my car is a daily driver and i dont care about ride comfort (i like it rough ), just want a set that will keep a pretty sleek ride height and give me very good 60 foot and launching characteristics.
Thanks for any help.
Old May 17, 2003 | 12:16 PM
ttt
Old May 18, 2003 | 03:25 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
The drag launch kit will not be rough. It will be hell trying to drive it on and off an interstate. The drag launch springs are never ment to handle well. The are designed to give you optimal weight transfer.
I'll be going w/ the moroso trick springs. Basically the same thing as the drag launch. I'm just trying to figure out how heavy my car is.
Old May 18, 2003 | 03:47 PM
thanks for the relply, i really care care rough or not.
i might just buy them and try them out, i wanted to lower the car and have great launching.
i dont really care for handling to much. and i think the prokit was based on getting the car lowered and for handling, like i said it didnt know that their was a such thing as the eibach drag launch springs when i bought the prokit.
i would hope the drag launch springs wouldnt lift the car at all.
Old May 19, 2003 | 06:52 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I know w/ the moroso springs you order the correct ones for your weight and then cut them down to size for the desired ride height.
Old May 22, 2003 | 02:03 PM
Ezey Go's Avatar
I have the Eibach drag launch kit on my car and I love them. My car still handles pretty good. It doesnt lift the car but I did notice that the front sits little lower than the back. I think it gives my car more of an agressive stance. Let me know if you have any other ?'s.
Old May 22, 2003 | 04:19 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I just got the Eibach drag springs along with the PA racing tubular a-arms. I haven't been to the track with them yet but they handle fine on the road. You just have to be smart about it.
I also have the Lakewood 70/30 struts, 50/50 shocks, Spohn relocation brackets, airbags, 24mm rear sway bar, no front sway bar, jegster frame connectors and hotchkis LCAs and panhard rod.
With that kind of suspension, the car will drive ok but don;t try taking any turns at 60mph. The last time I had the car to the track, I had the stock ws6 springs in and the stock a-arms and it pulled a 1.5x 60' time.
I am hoping to knock that down into the 1.4x range with a higher convertor and my new cam/heads.
I think it is a good combo and you will like it a lot.
Good Luck!
Old May 22, 2003 | 06:24 PM
thanks alot
if u dont mine me asking where did u get the drag launch kit?
http://www.genxmuscle.com/store/9306.140 this is the price deal i could fine because of it having free shipping, and also i just ordered my lakewood front 70/30 struts from jegs and they said i have to wait about 3 weeks because they are special order is that the same kinda wait you had?
the drag launch i think comes with right a pasengers rear bag so i think that should be good enough to help me launch.
Old May 22, 2003 | 11:08 PM
Ezey Go's Avatar
I got mine from summit. They were $269.95 so they are a little bit more than genxmuscle. I got them 3 days after I ordered them. Later.
Old May 22, 2003 | 11:54 PM
any lowering happen with these springs.
Old May 23, 2003 | 12:22 AM
Ezey Go's Avatar
No. My car wasnt lowered before I installed them. After the install it still has stock height in the back but the front lowered maybe .25 of an inch. Just enough to make the front dip a little. Id post a pic to show you what I mean but I dont have one.
Old May 23, 2003 | 12:58 AM
ok sounds like i will get them and see what happens.
thanks for the help guys.
Old May 23, 2003 | 02:35 AM
Ezey Go's Avatar
Thats what were hear for.
Old May 26, 2003 | 10:24 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Shouldn't the front be higher then the rear so more weight it put to the tires on launch?
Old May 28, 2003 | 05:50 PM
Ezey Go's Avatar
The reason the front sits lower is because the springs in the front are not as stiff as the rear. This is so when you launch the front will come up faster due to the less stiffer springs, this in turn plants your rear wheels firmley to the gound due to the stiffer rear springs. If the back sprigs were less stiff then your wheels could still break loose due to the lack of firmness. I hope I explaned it good enough. If anyone can explane it better then please do. Later.
Old May 29, 2003 | 12:09 AM
and thats exactly why i bought a set! just what i want.
Old May 29, 2003 | 12:14 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
If you care at all about traction, dont get the Pro-Kit. The stiffer springs actually hurt weight transfer.
Old Jun 15, 2003 | 09:55 AM
i put in drag launch rear set, when i opened the box the one rear spring had the airbag already inside so i assume thats the right spring for the rear passengers side.
te rears were simple, but the fronts ones are way bigger than the stockers. so what do u guys think about me using the pro-kit front springs instead? i was running out of time and had to put things together
https://www.thirdgen.org/techbb2/sho...hreadid=185483
thanks for the help.
Old Jun 14, 2004 | 09:37 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
how bad is it to install the rear? I've done rear springs before, but never with the air setup. I guess I'm wondering what all is involved in doing the airbag.
Thanks,
Mike
Old Jun 14, 2004 | 11:23 AM
the air bag is already in the spring when u get the kit, its a pieces of cake, a vavle, some hose and zip ties and ur done. it all comes in the kit.
i still have mine for backup, but i am using the pro kit now front and rear. the drag kit made my car way to high.
Old Jun 14, 2004 | 07:34 PM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
I vote for the Pro-kit, thats what i'm running on mine. I'm in the same boat, street/strip car, i wanna look good and go fast. I've done alot of searching and reading and went with the Pro-kit, along with some QA1s, relocation brackets it'll be fine and i highly doubt u r running the amount of power i am It'll be wheels up launches at the track and i'll be looking good driving home
Old Jun 16, 2004 | 04:20 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Yeah I noticed that when I installed the prokit I lost some traction, however, I feel that I more then gained it back when I installed my tubular LCAs and panhard rod. I think some nice relocation brackets and an aftermarket torque are (like the non-tailshaft mounted spohn model) would make a huge impression on the 60'
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Drone358
Dec 10, 2015 08:16 PM
tonys91rs
Oct 10, 2015 03:31 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
