Widening aluminum wheels
Car: '89 RS Convertible
Engine: 355
Dayam. File this one under the "Spending way more than it's worth and way more than it'd cost to just buy the ones I want" category
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
the gta wheels look nice and instead og oing to an aftermarket wheel why should he not stay with the gta wheels? they look better and give a more stealth appearance which is what he is going for now.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
http://www.fixrim.com/index.html
i found that by searching for 'widening wheels '
they might be able to help you out, give them a call and see if they do that, and what it would cost, ect.
Didn't your mother teach you that if you don't have anything good to say, don't say anything at all? I suggest you start following that on this board.
I cleaned the profanity out of this thread, let's keep it that way
Steve
I have considered widening my GTA wheels also. What are your thoughts--1" on each side or 2" on one side (which side?)? Maybe using a front wheel widened out 2"?
I like the idea of 'stock' appearing GTA wheels with some serious rubber mounted on them. After all, they are very, very light weight.
I've also considered narrowing the fronts to maybe 6" but believe I've seen some Beretta wheels (or some similar vehicle) with wheels that look a lot like the GTAs. Thoughts?
jms
jms
Car: 98 Camaro SS
Transmission: M6
Not quite sure... but i'm leaning more towards on the inside.. That way the welds won't be visible.. (less work to polish the new aluminum anyways...)
I know there are some companies around here (orlando,fl) that will cut the barrel out of a wheel and weld in a new one.. I just have to find their numbers...
My 92 Z28 16" wheels on the rear are now 10" wide for the 26x11.50-16 ET Streets and the front are cut down to 6 1/2" wide for 215x60-16s next time I have them off I will post some pictures.
Link to some other wheels http://www.ws6.com/wheels.htm
Jerry
Jerry
Engine: 355
Steve
Steve
I just assumed that the cost of doing that would be way more than any aftermarket (or even factory) wheel would ever cost. I see on one of the posts some guy had it done for 225 a wheel...more than I'd spend on 'em, but like he says...An items "worth" is subjective to the owner.
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
How much would you charge to make my back rims into 10 inchers. I have some extra wheels if you need material.
I have been interested in this for a while.
Does anyone make a 315mm drag radial for a 16 inch rim?
Thanks,
Kory
Thanks,
Kory
Thanks,
Kory
Thanks,
Kory
The only reason I made 16 x 10s was for E.T. streets and the ones I run are 26x11.50-16 and work better on a 10 inch rim. Now Hoosier has a 28x14.50-16 quick time pro and that's my next set of tires.
I run 16 inch Nitto DRs on the street and have major traction problems with 3.73 gears and a Yank ss3600 converter. The only DR that's wider is in 15 or 17 inch so the next set of rims I do will be 17 x11s and that's after I finish a new motor for the car.
Link to motor https://www.thirdgen.org/techbb2/sho...hreadid=186969
Jerry
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Does M&H still make the 305/40/16? That would fit nicely without any bulge.
I've thought about having mine done. What I really wish for is some 17" GTA wheels :hail: That would be nice.
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
You can buy some cheapo and light stock car rims for under $75.00 each to put slicks on. Jerrywho did a great job on his, but in my opinion, that's a little shakey for street use.
Jerry
P.S. you don't want to know the cost for them .
But I will post pictures when done.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
Originally posted by JERRYWHO
I did my wheels at no cost to me only my Labor.
Jerry
Jerry
oh my ***, that is sick..... i am in awe.:hail: :hail: :hail:
i also am a big fan of "stealth" the other day i got pulled over doing 70 in a 55, no ticket, why? because my car apears totaly stock, is white in color, and becouse i was dressed well.(just got off work). if i had been wearing, say, my TGO tee-shirt
, and had aftermarket rims and tires, i would have gotten that ticket. it's all about "stealth" that and kissing piggy ***. that helps too. "yes officer, of course i will drive 55 from now on, no i totally agree, i was being rather inconciderate to other road users, yes officer......"
I have also been hoping to find a company to make 17 inch WS6 rims. I want to factory crosslaced rims, but I want wider and in 17 inch. Dante Designs makes 17 and even 18 inch chrome IROC rims. Wonder if they'll ever make em for the WS6. JERRYWHO-I can't wait to see the pics of your big and bad crosslaced/honeycomb, "whatever you wanna call em," rims. If you find a cost effective way to make more let me know because I'll be first in line to get em. I was going to call Dante Designs and see if they had any plans to make these.
Hate to bring this thread back but does anyone have any other companies they know of that widen rims?? i would like to get a few quotes on what it would cost. is there anyone who has had this done???
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Jerrywho,
Where did you pick up the inner section of the rim, or did you just cut off the inner lip, and weld in a 2" strip? I'd love to do this myself. One of the guys at work just sent a set of rims to weldcraftwheels.com in MI ($175/wheel). They should be getting here any minute now.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
(yes i know this is a old post)
went to their site and called the local dallas store..
$209 a wheel to widen up to 2"... they dont widen more then that.
so i could make my 16x8" rims 16x10"..
just called www.weldcraftwheels.com and got a quote to make my 16x8s into 16x11s.... 185 a wheel..
now i just have to see if they make a 315 series 16" tire.. lol.
Car: 1990 Camaro RS
Car: 91 Camaro Vert
I think that hoosier makes the R3S04 in a 16" that wide. but you might not want to run that on the street. but you would have wicked good handling
for the hell of it, i looked them up just now (can you tell its a slow day at work? )
275/45ZR16 is the widest 16" they make.
Car: 1990 Camaro RS
if you are in a competative class, that doesn't allow wider than an 8" wheel, and you win, i bet you get protested
275/45 i would think is a nice fit on a 10" wheel.
Car: 91 Camaro Vert
my next set of tires is going on my new set of rims anyway, so its a moot point for me... i was mostly curious about price.... that and well... i have a lil side project that envolves taking a small, 4cyl car, backhalfing it, and sticking a SBC in there... i think widening the stock rims would take sleeper up to the next level.. (its already high up there)
new rims are already 17x11 and 17.9.5.... going to go with a 315 series rear.... not positive on the front..
btw, side note, i have a tire size calculator...
http://josh.swoca.net/board/mrdude/T...c/Tirecalc.htm
incase anyone wants to compare sizes.....
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
This thread is exactly what I am looking for...I am apparently one of the idiots referenced early on...
I have two sets of GTA rims (for my GTA
) and want to keep the stealth factor.
When you add up the costs for the rims I want in 17 inch size, it is $1000, plus 4 new tires. Having two wheels widened at $400 total plus tires is a better deal for me right now...I would like the 16x10 on the rear...
Now the tire choices are pretty limited obviously, but at least it is an option....and if someone made crosslace 17" rims that looked like original, this wouldn't be a discussion
) and want to keep the stealth factor. When you add up the costs for the rims I want in 17 inch size, it is $1000, plus 4 new tires. Having two wheels widened at $400 total plus tires is a better deal for me right now...I would like the 16x10 on the rear...
Originally posted by askulte
Jerrywho,
Jerrywho,
If you take 91-92 16" wheels and cut 2" off the inside of the fronts and cut 4" off the inside of the rears then match the front outers part and the the rear inside part and weld them you will get a 10" rear wheel thats 1 3/8s wider to the inside and 5/8s to the outside and then take the inside part from the front and the outside part from the rear you will get a 6" wheel for the front that is 5/8s narrower on the outside and 1 3/8s on the inner.
If you just band a set of rears 2" wider you will need to run wheel spacers to clear the body. The way I did them the factory offset of the 91-92 wheels helps make them fit.
Jerry
PS if you need a full set done my local guy will do them for $125 each.
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Jerrywho,
Jerrywho,
Supporter/Moderator
Car: '89 Z28tt
My co-worker got his Caprice rims back from Weldcraft, and this did weld in a 2" wide band, so 2 welds per wheel, plus the butt weld connecting the band (I wonder if the word "b u t t" will be bleeped out by the board software?). The welds were very well done, and we checked the runout with a test indicator on a Bridgeport, and everything was good.
Originally posted by TPl383
bringing this back from the dead. Jerry did you ever get them GTA rims done....
Chris
After getting 16" GTA wheels I found out the center is to small for a 17" outer band. Now the 91-92 Camaro wheel has a 15.4" center and will fit in the 17" Budnick wheel band with no problem. I have a set but other projects are in front of them now.
Jerry
morrow
Jan 13, 2024 12:29 PM
ambainb
Apr 25, 2016 09:21 PM
