Brakes are pulling HARD to the left.......
Old Jun 16, 2003 | 09:35 PM
FLYNLOW92rs's Avatar
What's going on here?
When i hit the brakes the car literally turns to the left, it's pretty damn bad.....
What could be the problem.....
I read over some posts that mention stainless steel braided lines for the front?? Any links, numbers or anything to these would be great? Or is something else the problem that i should check out......
The car has new rotors and peds, both replaced within the past 2 months....
Thanks in advance
Old Jun 16, 2003 | 11:06 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
possibly a seized left front caliper. Jack it up and see if you can turn the wheel by hand, if not, it's frozen. think of a bulldozer or tank, you slow down one side more than the other to turn...the same thing may be happening to you.
Old Jun 16, 2003 | 11:35 PM
BTS88IROC's Avatar
I had the same problem when I bought my current iroc. Turned out to be the brake lines. You may want to replace them if you haven't in some time.
Old Jun 16, 2003 | 11:40 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Yes, it could either be the left front caliper, or the passenger, front side brake line could be clogged.
If the brake line is clogged then your in luck, its cheap as hell, and relatively painless on your wallet. ^_^ About $10 for new rubber brake lines.
Oh yeah, Flynlow, that signature looks great. Who made it?
Old Jun 16, 2003 | 11:43 PM
BTS88IROC's Avatar
Maybe not necessarily clogged. It might be getting old and worn and just be expanding and not as much pressure is getting to the caliper.
Old Jun 17, 2003 | 12:06 AM
Thanks again Fruityone for the signature, looks great.....
Does anyone have a link to some stainless steel braided line for the brakes, i might as well upgrade now.....
Old Jun 17, 2003 | 12:56 AM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
One brake may be getting more fluid then the other. Did this happen right after you installed the new rotors?
Old Jun 17, 2003 | 01:15 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
p/n 361-28A180 on jegs for disc/drum setup
and p/n 361-28A190 on jegs for disc/disc setup
those are the p/n for the earl's hyperfirm SS brake kit. Heard a lot of good things about them and plan on picking up a set for my car soon.
Old Jun 17, 2003 | 08:28 PM
Before the new rotors....
Thanks for the suggestions, I willl try taking off the rim this weekend, to see if they are frozen...
Old Jun 21, 2003 | 08:02 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
i think you'll find the RIGHT caliper is frozen. when you step on the pedle, the left caliper is the only one that works...so you pull to the left! it's very common with these GM brakes....especially if you keep the car out in the elements and parked for long periods.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
