Will I notice a difference?
Car: 2002 Formula Firebird
Transmission: 4l60e
I was underneath my car doing an oil changed and I noticed all my bushings are SHOT. Especially my sway bar bushings. They are cracked and dry.
Im going to order a set of poly bushings from spohn and I was wondering if Ill notice a big difference?
Im going to get a set of eibach sportline springs also.
I hope to have much better handling
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
you will notice a BIG difference. will firm up the suspension real nice. big improvement in steering response.
have you had your front end rebuilt? how many miles on the car?
-Schultzy
-Schultzy
Transmission: 4l60e
About 130k on the chassis. I was looking at the moog kits from spohn. Can I do all the front end work myself? Besides getting it aligned of course.
You don't need special tools to change it all do you?
I dont know If I need it. Car steers ok just isn't to stiff.
Front end rebuild = ***** joints, tie rod ends ect??
Did you install a set of SFCs ? If not I don't think those poly bushing are going to do much for you. Your car will just flex more. If you do have SFC install then you should notice a slight improvement.
