so there is still no source for these spacers?
Car: 1992 B4C 1LE
These spacers that are used when building solid rear control arms. They fit into 3/4 inch heim joints to take up the space on either side of the joint. They also "bushing" the factory bolt to fit the 3/4" hole on the joints. There is no source for them still with out making them or having them made?
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Get me the specs.... I have a few boxes of those same type of spacers, actually from Mustang lower arms, but they -may- work. PM me if you want.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
The larger OD should be about 1", smaller OD .750, the ID is 1/2", height of larger shoulder is 3/4". I'm not sure about the height of the smaller shoulder, but I am interested in a set of 8 too.
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
What price range are you looking at for these spacers, I have a machine shop that made some for me maybe if enough people are interested I could have a few more sets made?
Car: '88 Formula
I would say no more than $10 to $15 for a set of 8, that might be too much even. It would actually be cheaper to get 3 pieces together but much more inconvienient. I'm thinking the material should be some pretty dense aluminum or an average grade of steel.
Car: 84 Z..err 92 now
Engine: 402 LS1 Procharged-14 psi-629 hp!
Try here:
Coleman Racing Products
Car: '88 Formula
Yeah... thats what I'm talking about. They want something like $4 each. Even if they are the perfect size that is $32 for a set.
This is what we are trying to do. Coleman is listed at this link as a supplier, but its not quite right. The listed source isn't bad for the reducers, but the supplier for the spacers is out of stock and I think I read were they require a pretty large min. order.
http://www.jonaadland.com/Z28/Mods/L...minumLCAs.html
FYI, Jegs has the rod ends for about $29 each, but they are pricey for the jam nuts (5 per pack.) Coleman has the jam nuts nice and cheap.
I'm sure there are some local machine shops around who would do it for us without too much trouble if they get good dimensions. I have a place in mind that I will try and get in touch with soon. But I'm not holding my breath.
I am currently building a panhard rod from scratch.Its costed about $100 so far. But I am have access to a machine shop so I don't have to pay shop rate.The material for the spacer would cost you about $10.00.If you took it to a shop it would be fairy expensive paying shop rate. The Colemans are cheap if they would fit. The problem with the aluminum LCA is that aluminum will work harden and could crack or break. The ones they sell are really for racing use.They don't have to deal with potholes or continous stop and go traffic. Also you need a rod thu the rod end to transfer the compression to entire length of the bolt.The ones in the picture on that site aren't correct.It would work fine and probably never have a problem on a low horsepower car.But for my piece of mind I used a 3/4 tube thru the rod end. Then made spacers to keep the rod end from moving side to side. It was fairy easy.I saved 90 bucks over what Spohn gets for them.But I have the machines to do it.
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
That sounds like the way to do it. A 1/2"IDx3/4"OD tube for the rod end to ride on, and 2 short 3/4"IDx1"OD pieces to keep it centered.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by slowTA
Would you make us some?
wanna make me a set for a price??? PM me or email me at MrDude_1@excite.com
I will take a picture and let you guys know . I have wednesday off to work on my car. Supposed to be nice out,at least I hope so.
Car: 91' Camaro
Engine: 383 ci
These are the pieces I have a ton of.... I will try to measure them tomorrow. If they are the correct size, I'll sell them for $1.00 ea. Sound fair?
Car: 91 Camaro Vert
if they are the correct ones, that would be GREAT..
my only prob is, i donno how confident i feel using thease smaller homebuilt LCAs...... im pretty damn abusive to my car.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Car: 1992 B4C 1LE
Originally posted by ebmiller88
How 'bout these??
http://www.cmwraceparts.com/Chassis/Chassis17.html
Ed
How 'bout these??
Ed
Car: '88 Formula
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
