Spohn stuff sqeaks A LOT??
Old Jul 29, 2003 | 04:25 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I just put in Spohn SFC, LCAs w/ brackets and Panhard bar
It's all the poly bushings, but DAMN does this crap squeak. It's like I stopped the squeaking t-tops, but now my rear suspension picks up the slack. Anybody else had this problem or now how to stop it?
Old Jul 29, 2003 | 04:49 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Did you grease them???
Old Jul 29, 2003 | 04:55 PM
Car: 91 RS
Engine: 350 TBI
yup
even bought a big tube of that stuff
Old Jul 29, 2003 | 06:30 PM
Hg's Avatar
Hg
Car: '87 Z
Hrm... ya got me then.......
Old Jul 29, 2003 | 07:02 PM
Kandied91z's Avatar
that's a good reason why people don't like them. the bushings are great for their intended purpose for racing but on street cars they are harsh and noisy. they definately have their ups and downs. best bet is to make sure they are lubricated properly on ones that are suppose to and enjoy.
Old Jul 29, 2003 | 07:28 PM
BORLAZ06's Avatar
thats wierd they squeak even with the grease. maybe they made the polly stiffer use more lube
Old Jul 29, 2003 | 08:03 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I have the Rear LCA's, Panhard Bar with Poly bushings and SFC's and if anything they got rid of my squeaks & rattles. The car is tighter now then when it was new (orignal owner of 87 IROC).:hail: To Spohn Parts.
Old Jul 29, 2003 | 08:39 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I know my Spohn LCA are REALLY squeaky too. I'll try double dosing the grease when I put the rear end back in and see what happens.
Old Jul 29, 2003 | 08:59 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Always pre grease the parts before you install them. You put it together then just shoot grease into the zerk and it wont distribute to all sides. Also tighten things down only at ride height.
Old Jul 29, 2003 | 09:29 PM
Car: 91 RS
Engine: 350 TBI
So I should try to grease the outsides and the insides and the little groment thing? I just did the gromet thingie. I guess I'll go yank them out and grease the part that comes in contact with the bracket.
Old Jul 29, 2003 | 10:43 PM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
One word:
Polygraphite.
Old Jul 30, 2003 | 04:33 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Or you could get a cutout so you cant hear the squeaks
Old Jul 30, 2003 | 06:57 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Panhard and LCAs on mine were greased before install - no squeaks.
Old Jul 30, 2003 | 08:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I use synthetic oil. 15-50 Mobil 1 in a small pump can with a nozzle. No noise what-so-ever. First tried synthetic gear lube but the stench was too much. Maybe MTL would work too, w/o the smell.
Just put a few drops on each bushing and the squeaks are gone. I've found that most of the squeaking is from the sides of the bushings rubbing.
RBob.
Old Jul 31, 2003 | 07:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Note sig. No squeaks at all. Lube the racals.
JamesC
Old Jul 31, 2003 | 07:58 AM
Car: 91 RS
Engine: 350 TBI
Racals??
Old Jul 31, 2003 | 09:52 AM
MdFormula350's Avatar
i had some noise after my stuff, i put more greese in them after installed and i also lossened up the bolts and nuts holding the pandhard and lca's in, i seem to tighten down nuts and bolts too hard and i think i was binding the poly bushings to much.
now noise seems to be almost gone, and now i have a firmer ride so its worth it.
Old Jul 31, 2003 | 12:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I use the energy suspension lube and don’t have any squeaks. It seems to stay in there a lot better then the lube I got from Spohn.
Old Jul 31, 2003 | 04:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't have Spohn parts, but I redid my front suspension with ES bushings. The instructions in the pack said to disassemble the bushings, lube all surfaces, then put them back together. I pounded the center sleeve out of the poly bushing with a hammer and punch. Then I pounded the poly out of it's outer shell with a piece of pipe and a vise. Lubed the poly and metal completely with the white/clear/supersticky grease, and put them back together- no squeaks.
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
FormulasOnly
Sep 6, 2015 10:42 AM
Jetmeck
Sep 4, 2015 12:29 AM
