what does ur thirdgen weigh?
Old Aug 5, 2003 | 01:52 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
just wonderin what everyones thirdgen weighs, probably gonna very alot heres mine...
305tpi 5spd,hardtop emissions delte, ac delte, rear seats gone, spare tire and jack removed, rear shade removed. 3350 with me in it and a 1/4 tank of fuel
with everything back in minus the ac and emissions it weighs 3390 with me in it and about 1/4 tank of fuel.
i just put the ac back in cause i cant stand the heat so its probably gonna be like 3420 - 3430 now.
Old Aug 5, 2003 | 12:56 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
3440 lbs without me in it. I got it weighed last year.
Old Aug 5, 2003 | 04:00 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
In the sig.
Old Aug 5, 2003 | 11:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
with 1/8th tank of gas, as run down the strip with me in it, full stereo and junk in the trunk..
3615lbs
i weigh roughly 210
so
3405
Old Aug 6, 2003 | 10:19 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Last time at the track, my car weighed 3540 with a full tank, me in it, and stereo equipment. It may not seem like much, but I have taken out a lot of weight:
a/c 25lbs
spare & jack 30lbs
aluminum heads 50lbs
baer brakes 20 lbs
fiberglass hood 30lbs
fiberglass hatch 50lbs
aluminum ds 5lbs
I did add some weigh in too:
subframes and stb 25lbs
stereo 60lbs
12 bolt rear 60lbs
Old Aug 7, 2003 | 12:06 AM
iroc22's Avatar
3205 with 1/4 of a tank.
1988 IROC hardtop 305 TPI 5-speed G92, Factory A/C delete. Only power option is power windows. No spare tire at the time.
Old Aug 7, 2003 | 11:02 AM
kevinc's Avatar
Car: 1982 Z28
3333 total:
939 lb front driver
940 lb front passenger
738 lb rear driver
716 lb rear passenger
This was measured using a Rebco 4-wheel plate scale instrument on a poured-concrete garage floor surface, without me in the car, 1/2 tank gas, spare tire and jack in place, partial interior (no back seat or headliner).
The riddle is where that extra 22 lb on the driver's rear wheel is coming from. Only guesses right now are the weights of the exhaust tailpipe (single outlet Spintech muffler) and the gas tank filler neck.
Old Aug 12, 2003 | 02:23 AM
DREGSZ's Avatar
I weighed mine in 2 weeks ago.
It's a stripped down SCCA/ American Iron X race car.
1984, 377 ci, Tremec TKO, Ford 9" (4.11), gutted with 1/8th" lexan rear hatch and no side windows, '82 fiberglass hood:
3070 with 3/4 tank of gas...
about 3000#s dry
Old Aug 12, 2003 | 09:46 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
about 3000#s dry
hmm.
so the diff between a gutted all out race car
and a full interior, heavy stereo system fully optioned vert is:
405 lbs.......
based on yours weighing 3000 and mine weighing 3405...
btw im only taking into account straight line accell and not the benifit of havinf less mass to turn....
now my car dynoed at 152hp.. (L03, i know...)
so lets pretend you have the same..
according to the Finding ET and MPH with Weight and Horsepower calc at http://www.fbody.com/calc.htm
you would run a 15.74
i would run a 16.42 (according to the calc.. really ive run 16.0 )
this is for the same hp..
now if i leave my weight in there...
i need 172hp in order to do a ET of 15.75........
so in my lil game, you gained roughly the accel equiv of 20hp at the cost of totally gutting your car
Old Aug 12, 2003 | 07:58 PM
DREGSZ's Avatar
Yes, but since my 377 turns out about 550 HP, what does your little book say my 1/4 MI ET should be???
Old Aug 12, 2003 | 11:26 PM
IrocSS85's Avatar
mine weighs 3080 w/half tank of gas.
full interior, stereo w/amp and subs, (cheap small ones, but they are still there)no a/c, fiberglass hood, manual strg., alum. heads, mini starter, alum. w/p, real dual exh., all the little extra crap stripped out. (brackets, evap system, and so on). oh yeah, and drag lite rims.
chris
Old Aug 13, 2003 | 03:48 PM
formul8!!'s Avatar
Car: 2004 GTO
My '89 Formula 350 hardtop weighs in at 3,325 with just under 1/4 tank of gas, full interior, no spare tire and no A/C.
Old Aug 13, 2003 | 05:57 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
10.25 1/4 mile. 132mph traps speed
i never said it was accurate for anything except to compare to cars using the same formula.
just playin with numbers.........................
btw, same engine, mine would go 10.69 with a 127 trap speed (according to that calc)
edit: these times are without the drivers in the cars too...
Old Aug 13, 2003 | 06:59 PM
TexasLT1's Avatar
Car: '92 RS
hmm.....remote control?!
Old Aug 13, 2003 | 08:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol i thought of that..
but then i would have had to figure out the weight of the servos and reciever, ect....
in anycase, i couldnt add the weight of the drivers because:
1. we probly dont weigh the same
2. its easier to compare.
Old Aug 13, 2003 | 08:22 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 86 Trans Am 305 carbed 5 speed, t-tops, pw, pd, pm, no rear seats, leather w/power up front, no a/c, no smog, small stereo, 1/4 tank of gas.
3380 without me.
My 88 Formula 305 TPI Auto, A/C, Smog, full interior, pw, pd, Ram Air II Hood, aluminum spare with jack and air can, t-tops, 1/4 tank of gas. Car is pretty much bone stock.
3400 without me.
Old Aug 13, 2003 | 08:23 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by Zepher
My 88 Formula 305 TPI Auto, A/C Smog, full interior, pw, pd, Ram Air II Hood, aluminum spare with jack and air can, t-tops, 1/4 tank of gas.
3400 without me.
heh, your car weighs as much as mine.. and mines a vert. o_O
Old Aug 13, 2003 | 08:26 PM
Zepher's Avatar
I read that the verts didn't have any extra weight over the the normal cars since you don't have the 80+ pound glass, so the chassis stiffening parts & vert top offset the weight of the rear hatch glass.
Old Aug 13, 2003 | 08:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
I read that the verts didn't have any extra weight over the the normal cars since you don't have the 80+ pound glass, so the chassis stiffening parts and the vert top offset each other.
thats what i was trying to say earlier, however im always told im wrong... by alot of people.
my logic:
i have 2 poprivetd sheetmetal "U"s under the car... and a trunk lid.
they have a huge glass window. and B pillars.
Old Aug 13, 2003 | 08:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
the calculator at fbody.com isnt very accurate, try www.smokemup.com for a lot better calculator.
Old Aug 13, 2003 | 08:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
one prob. they want me to "log in" first.
i dont want to join another msg board just to use the calc.
Old Aug 13, 2003 | 08:51 PM
Zepher's Avatar
my logic:
Also, a glass t-top car weighs an extra 50 or so pounds, so add that to the 80+ pounds of the rear hatch and the 20 or so of the wraparound that I have and that is 150 extra pounds, give or take a few.
Old Aug 13, 2003 | 10:06 PM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
3300 lbs with a full tank of gas.
Old Aug 14, 2003 | 12:45 AM
iroc22's Avatar
Whenever I looked under my 89 Vert, I'd always wonder if those things would actually stiffen up the car enough in a crash; they looked pretty weak. And they definitely dont weigh much looking at them.
Old Aug 15, 2003 | 07:24 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
So what does a full weight vert weigh? MrDude_1 is your car an auto, and have you done anything to lighten it up?
Old Aug 15, 2003 | 01:53 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
She's light, thats all I'm saying!
Nah, actually it weighed 3,278 with less than 1/4 tank, but that was before the 6-speed swap, exhaust swap, removed all emission crap, removed 20 lbs of not needed wiring (old alarm/stereo wiring from previous owner), and misc. mods.
I'll find out her new weight when I take it to the track in December. I'm figuring arround 3,100 or so with 1/4 tank.
Old Aug 15, 2003 | 04:15 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Hang on a minute, the calc on f-body.com doesn't take into consideration transmission type, or more importantly, final drive ratio. Is there a calc out there that will?
Old Aug 15, 2003 | 07:16 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
nothing has been done to lighten the car, athough i did take the spare tire and jack out... but i added in a 2 amp stereo system, subwoofer, and replaced the plastic back window with glass... so it should weight the same as stock.
Old Aug 15, 2003 | 08:24 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Is it an auto?
Old Aug 15, 2003 | 09:48 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
yup this one does, ist very specific.
calculator
Old Aug 16, 2003 | 06:00 AM
Car: 83 Z28
Old Aug 19, 2003 | 04:47 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Where are you guys getting your cars weight from ????
I stopped at a Truck stop a few weeks ago so I could see what the scales said about my ride.
---------> 1984 Berlinetta was 3600 pounds.
I was very surprised by this so I brought my 95 Z down there and gave the guy another $7.
---------> 1995 Z28 3700 pounds
Now I expect that the scale is off just a little, but probably close. The Berlinetta has a fiberglass hood and removed my AC system (for now) but added 8 speaker BOSE sound, subframe connectors, a T56 and MANY other parts over the years. The Z has also been modified from it's stock form. < EDIT > Both cars had a full tank and me in the car when weighed.
My question - are you getting on the scale at the track or somewhere else ???
Old Aug 19, 2003 | 10:55 PM
iroc22's Avatar
Re: ?????
I took mine to a shipping/receiving warehouse which has a trailer scale that I could fit my whole car on and it comes up with a digital readout. My Jeep Grand Cherokee weighed in at 4350lbs so 3205lbs for the IROC seems about right.
Old Aug 20, 2003 | 01:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: ?????
at my local track they have a drive on scale where you drive the whole car on it and it gives you a digital readout...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
