welding in BMR's bolt in LCA brackets
Old Aug 19, 2003 | 10:24 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
do i need to align anything, or do i just bolt it in and weld it up. i mean if i bolt it in, and mount the shock and LCA then isn't it in the right spot already. just weld around the edges.
Old Aug 19, 2003 | 11:27 PM
bes217's Avatar
In theory that sounds like it would work just fine. But in practice I would have no idea whatsoever. Goodluck.
Old Aug 20, 2003 | 12:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yeah, bolt it down and weld.
Old Aug 20, 2003 | 02:09 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
cool, guess ill be putting them in. but ill only be using my stock arms till i order the new ones.
Old Aug 20, 2003 | 05:53 PM
25THRSS's Avatar
Are the spohns the same way or do you have to make any measurements?
Old Aug 20, 2003 | 06:23 PM
91Z28-350's Avatar
Not really measuring, just make sure the LCA swings to both holes before welding.
Old Aug 20, 2003 | 09:38 PM
25THRSS's Avatar
So the BMR brackets are easier to install than the spohns?
Old Aug 20, 2003 | 10:58 PM
jeffsbluez's Avatar
Car: 91 z28
Sure are. Steve makes great products but the BMR "bolt in " brackets are much easier.
Old Aug 21, 2003 | 09:46 AM
flyway190's Avatar
Something to think about when installing LCA relocation brackets: Suspension cause problem with driveshaft?
Old Aug 21, 2003 | 10:41 AM
jeffsbluez's Avatar
Car: 91 z28
That is why you buy the BMR "bolt in " brackets and then weld them if yo wish. There is no need to measure anything. They are a little more expensive than the weld in type but IMO well worth the money.
Old Aug 21, 2003 | 03:50 PM
SteveSpohn's Avatar
Actually, our weld in brackets do have locators, the full length back plate (others don't have this). It's actually a very simple install, you slide our bracket over the OEM bracket, you make the inside of our black plate tight and flush against the outside of the OEM bracket back....that's it.
I've probably installed over 50 pair myself, always use the above method, and when I connect the LCAs to the bottom hole and take some measurements, the rear is dead square.
On the other hand, if you have a bolt-in type bracket that has a positive locator (the bottom shock mount), and you install them and take your measurements and your rear is not square, you have no way of adjusting the brackets unless you cut off the extension that goes to the shock bolt. You can't just trust the bolt in bracket, you should always measure if your rear is square. Your factory mounts could be off, their bracket could be off, your car could be tweaked, etc.
With a weld in bracket, you can just tap it front or back if it's needed.
Steve
Old Aug 31, 2003 | 10:05 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i had a problem with this too, and i just ended up buying the bolt-ons instead. i doubt the shock mounts or the brackets would be off much if any. if it did cause a problem, at least you didnt weld them in, and they are still removeable. it sounds like the spohn brackets would work well too. i had the brm weld-on, and supposedly you weld the back side of the bracket....but it doesnt line up so theres no safe way to install it correctly that i could figure out. their instructions are horrible too. you cant just throw em on there and weld. if you did, you would run a high risk of your rear end being off-center....and i think you know where that would lead.
Old Aug 31, 2003 | 11:56 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
BMR will only work with ADJUSTABLE LCA's when the car is lowered. Lower stance causes the pinion to be rotated up to correct the angle- this will cause the rear wheels to move back in the rear fenderwells. Adjustable lca's will shorten and bring the wheelbase back to stock location, also seating the trans yoke to a good depth.
Attached Thumbnails welding in BMR's bolt in LCA brackets-rear-brakes-0003.jpg
Old Sep 1, 2003 | 03:38 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
An adjustable Torque Arm will also allow you to correct the geometry 2.8 speaks of....
Terrell351
Jun 13, 2021 01:13 PM
Genopsyde
Nov 11, 2015 10:46 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
