Got my Spohns welded in (SFCs) *Question*
Car: 1990 Iroc-Z
Well, they're certainly in there now, but I have a concern. The person who did it for me did not remove the carpet in order to weld on the inside. Rather, he welded them up on the outside. Anyone think this is sacrificing a significant amount of rigidity?
I still definitley notice an improvement in cornering and overall stiffness. Can't help but feel tho, that straying away from Spohn's recommended weld side (inside as opposed to outside) is hurting me some.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am pretty sure you only pull the carpet up because the floor pan gets so hot and could melt your carpet glue or even set it ablaze. You shouldn't weld anything in your car unless you have holes or something in your floor pan.
Car: 1990 Iroc-Z
You misunderstood me... lolI mean, the inside of the subframe, the inside track. Spohn welds them on the inside, where as my install was welded on the outside track.
So, please respond to this new info. Hehe.
Car: 87' Iroc
On the outside? You mean right on the floorpan against where rocker panels would go? I thought they were welded on each side on the outside....alstons are on the inside....either way...pulling the carpet isn't that hard....or you could pour water on the carpet where your going to weld to prevent a fire.....
Car: 1990 Iroc-Z
Argh. No. Look... when you brace the SFCs up against the underside of the car, there are two options as to where you will weld. On the inside of the SFC, or on the outside. So, imagine standing behind the f-body, and you see the two SFCs in place, the driver side SFC is welded on the outside, its left side. The pssngr SFC is also welded on the outside, this being its right side.
So, with this cleared up, does anybody think welding the SFCs on thier outsides (the sides closest to the door!) will sacrifice rigidity as opposed to the outsides (farthest from door!)
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I would recommend welding them on both sides to hold the car together better. It says in the instructions to do both sides. Since they are tubular and didn’t nicely go up against the underbody of my car I had to use round stock to fill in the gap.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
With SPOHN tubular subframes, typically you cannot weld them in on the INSIDE where the floorpan is. The problem with that is that there is no real way to get the welder tip in there because of the tubular arc.
One way around it, if you must have the INSIDE welded.... was devised by a friend of mine where you take a piece of steel, say 1/2 round diameter... and weld the steel to the floorpan, and to the subframe.
At the front mounting point and rear point of the subframes they should have the **** welded out of them.
Its not imparative to weld to the floorpan or inside, but I had mine done since they were square stock, not tubular. I also had to use some steel but only about a 1/4 diamater piece.
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Car: 1990 Iroc-Z
Well... ok then
It sounds to me like they're fine then. They ARE welded heavily on the front/back mounting, and along the outside rail... good - I was concerned - and it is unfortunate the wordplay confused everyone.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
