Stock spring rate specs - anyone?
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
Hey all-
Got an '89 IROC and have been contemplating messing with the suspension. Just deciding whether or not to mess with it has been hard enough, let alone deciding what to change/what parts to think about using. I haven't decided - but I'm still reasearching parts such as springs that are on the market.
My main ? is what are the rates of the original springs? If I knew that, at least I'd have something to compare to all the aftermarket springs out there. Are there any GM publications out or something stating what spring rates I've already got?
Sorry if this has already been answered - new here..... and there is a tone of great info here on springs already, just couldn't find a definite answer to this.....
Kevin
Kevin
Car: '89 IROC-Z
No ideas huh? I gather from a more recent post that they are liner rate springs - at least that can be said.
It would be nice to know - then we could easily compare to other replacment springs or stock springs on Vetts etc.
Buehler? Buehler?.................
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Stock spring rate specs - anyone?
Originally posted by onebluemcm
Hey all-
Kevin
Hey all-
Kevin
Car: '89 IROC-Z
Hey guys - very cool! Thank you, thank you, thank you!!!!
So between what laiky and and 84 1LE said - there seems to be a discrepancy - what gives? Are the Moog springs OE replacements with different numbers than from the factory - in actuality, a stiffer spring than original?
84 1LE - where did you get those numbers? I'm just curious, that's all - not questioning that they are correct, just interested.
All this interest is because I'm interested in maybe changing springs but I don't want to lower - want the original appearing height for authenticity sake. I might go down up to 1 inch, but that's all and it seems, unrealistic too. So, guess I'm stuck with stock height.
Oh, yeah - where do WS6 springs fit in - what are their specs if anyone knows? Actually, being new to GM cars in general, are WS6 springs only on 4th gens, or were they made for 3rd gens too, originally I mean?
Kevin
Kevin
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Aftermartket spring rates are all there own.I know in the back of some old TRW catalogs they use to list the spring rates for their springs.They were always different than factory rates.I would think moog is the same.If you want a factory spring rate your stuck with original replacement springs.As for the spring rates i listed.I got those from various G.M type manuals & magazine tech articles.GTAs came standard with WS6 suspensions.WS6 was optional on all other firebird models(t/a,formula,etc). 4th gens are different though.
Car: '89 IROC-Z
That helps to clear up the WS6 question.
So, it's not so much that I want to maintain factory springs rates as much as it is factory ride hight. Now I got to figure out what springs will give me a similar ride hight and have a different spring rate.
We all know Vetts tend to handle pretty dang well - I wonder what the spring rates are on them? Well, that's broad - lets say mid-90's vettes for instance? I'm well aware that the entire suspension package is much different on a vette, but just comparing springs, how do they differ?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Car: '89 IROC-Z
84 1LE
It does help - alot.
So, is cutting springs bad? Seems like I've read both ways - some people think it's ok and others think it's not a good idea?
I like your idea though - looks like you achieved the kind of drop I'm interested in getting. Tell me if this makes sense - if I wanted a stiffer spring rate and some lowering, like we said before, could I get both by cutting my current, factory IROC springs? Maybe a better question is - do I really want to cut the original springs???
Acutally, that brings up another question - do you know how cutting the springs changes spring rate to make it have a higher rate?
Definetly helpful - thanks for the input - the more the merrier ;-)
K
K
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
84 1LE
K
84 1LE
K
sailtexas186548
Aug 26, 2015 03:32 PM
