Spohn Lca's
Old Oct 15, 2003 | 04:43 PM
91 z28 350's Avatar
Car: 91 Z28
Spohn Lca's
Which Lca's should i get for my car from spohn the car is my daily driver and i goto the track very once and a while . I will also be getting relocation brackets with the lca's i get really bad wheel hop.
Old Oct 15, 2003 | 05:09 PM
conlinj's Avatar
Just get the standard non-adjustible ones, with the double poly ends since it's a daily driver.
Old Oct 15, 2003 | 05:23 PM
MdFormula350's Avatar
agreed. very happy with mine.
Old Oct 15, 2003 | 05:45 PM
91 z28 350's Avatar
Car: 91 Z28
ok now i just need to wait until i get some extra cash to buy them
Old Oct 15, 2003 | 05:50 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if he gets the lca relocation brackets won't he need adj lcas?
Old Oct 15, 2003 | 06:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No
Old Oct 16, 2003 | 03:26 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
How much of a difference will the standard Spohn LCAs make?
Also, what is the added benefit of having them adjustable? I'm guessing it helps with positioning when the car is lowered somehow?
Finally, is the road noise the only reason not to go for the sperical rod end LCAs?
Robert
Old Oct 16, 2003 | 05:10 PM
conlinj's Avatar
The adjustable ones help to dial in the angle between the driveshaft and the yoke on the rear itelf, the Relocation brackets help for lowering and are still a benefit on non lowered cars, sperical rod ends are pretty extreme and if the car is a daily driver it takes alot of compliance out of the rear of the car, it does increase road noise and a harsher ride
Old Oct 16, 2003 | 10:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, pinion angle is controlled by the torque arm. Adjustable LCAs allow the tracking of the rear end to be changed.
Old Oct 16, 2003 | 10:30 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
typicly i suggest the poly/spherical combo arms, that way you get the bind free operation, but the one poly bushing should keep the road noise down on a daily driver.
Old Oct 17, 2003 | 12:33 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I agree.
Old Oct 17, 2003 | 08:26 PM
CaysE's Avatar
Which end do you connect the rod end to?
Old Oct 17, 2003 | 09:00 PM
Most people put the rod end on the axle side.
Old Oct 18, 2003 | 12:36 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I have made so many adjustments to my car tunning it- there is no way I could NOT run adjustable LCA's. Where do I begin... I'll give the best tip I can- The shortest you can possibly run your LCA length's (without stuffing the driveshaft yoke into the tailshaft), the better the geometry can work to your advantage when it comes to cornering. (I don't know about anyone else here, but I have to spin my pinion up to the rear- basically rotating it backwards to even get my driveshaft in and out of the car- everything is tucked that tightly up under there)
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Jorlain
Oct 8, 2015 01:57 AM
luvofjah
Sep 26, 2015 08:28 PM
