replacing front a-arm bushings
Old Oct 16, 2003 | 12:52 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I want to replace my front control arm bushings with poly bushings, could someone give me a quick overview of whats involved?
Old Oct 16, 2003 | 01:14 AM
studdmstr's Avatar
Car: 91 Z28
Engine: LB9
Transmission: auto
Just do a search on the suspension/chassis/brakes board for it. It's been covered in depth many times.
Try this link, it seemed to have the most info after doing a quick search.
https://www.thirdgen.org/techbb2/sho...rm+and+bushing
Old Oct 16, 2003 | 08:51 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I did mine a few months ago, and burning the old bushings out worked the best for me. I just couldn't get them to press out. Then I destroyed the old bushing shells with a chisel and a BFH, and installed the new ES poly bushings with a ball joint press. Not too bad a job, but took a few hours. I paid a shop to do them last time and they charged me $100.
FYI..
Ed
Old Oct 16, 2003 | 08:56 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
alloy came up with a good way to do this when we did mine.
drill the rubber part out of the old bushing, then with a sawzall cut the center section out of the old shell, then use a punch/hammer/chissle, brute force to get the remain bit out of the arm. worked like a charm for us.
Old Oct 16, 2003 | 09:08 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
what i did was i used a cold chisel and wedged it between the lip of the bushing shell and the actually a-arm. i went around the perimeter beating the crap out of it for a few minutes and one the lip wsa raised and beat the hell i just pounded straight down on it. it came out l ike a champ.
Old Oct 16, 2003 | 04:49 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i just had a shop do it. they used an air hammer
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
