Replacing HIgh Pressure Power Steering Line
Old Nov 14, 2003 | 09:15 AM
gchu's Avatar
Car: 88 Iroc Convertible
The high pressure power steering line on my 88 Iroc (Auto/TPI) Convertible is leaking. How do you replace it? I am assuming it just unscrews like brake lines, but how do you bleed the system again to get the air out and the power steering fluid in?
I appologize for such a simple question, but wanted to make sure I don't wind up wrecking the gear box or pump in the process.
Thanks.
Old Nov 14, 2003 | 09:20 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yea, the line just screws in..
to bleed it:
lift the front wheels off the ground...
fill the PS pump with fluid
start the car and turn the wheels full lock one way to full lock the other way... do that a few times, then recheck your PS fluid level... fill if needed.. thats it.
alot easier then brakes eh?
Old Nov 14, 2003 | 11:38 AM
gchu's Avatar
Thanks for the quick reply - that does certainly sound easier than bleeding the brakes!
One more stupid question - why do I need to lift the wheels off the ground?
Old Nov 14, 2003 | 12:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
honestly, i dont know.
every manual that listed that procedure said to lift them off the ground.... i can take a guess at it, but im not positive. my guesses are
  • could just be that its harder to turn the wheel when there is air in the line
  • the steering box doesnt like stress without fluid
  • the pump shouldnt be strained when it has air bubbles going thru it?
remember im just taking a guess at it... *shrug*
Old Nov 14, 2003 | 01:17 PM
Morley's Avatar
So you don't flat spot your tires from turning thr wheels lock to lock several times without the car moving.
Old Nov 14, 2003 | 03:26 PM
gchu's Avatar
Thanks for all the info - I'm going to tackle this project this weekend. Hopefully I won't be posting how to change the steering box next week!
Thanks for everyone's help!
Old Nov 14, 2003 | 07:32 PM
Morley's Avatar
One thing. You'll need an 18mm wrench for the line fittings and most wrench sets don't include 18mm for some reason.
Old Nov 14, 2003 | 07:52 PM
ronterry's Avatar
Car: '94 Corvette
Yea, isn't that the dumbest ****, they love to go from 16mm or 17mm straight to 19mm????????????????????
BTW: I've had some that will want to strip with a wrench, and in extream cases I'll have saw off the line and use a deep socket. The best way to assure removal is use a crows foot. A crows foot will have a much more wrap around, and you'll actualy need to slide it on, but works wonders.
Good Luck,
Ron
Attached Thumbnails Replacing HIgh Pressure Power Steering Line-15481_lg.jpg
Old Nov 14, 2003 | 10:36 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
That, or a flare nut wrench...
Old Nov 15, 2003 | 03:39 AM
EvilCartman's Avatar
Car: '82 Z28
I bleed the PS by raising the front off the ground then with the engine off, turn it lock to lock a couple times. Fill it up then start the engine and go lock to lock a few more times and check the fluid level.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
wayshegoes
Aug 17, 2015 12:00 PM
jackhammer
Aug 15, 2015 10:04 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
