Brake Caliper
Old Nov 14, 2003 | 10:48 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Brake Caliper
Hey all quick question, I did a complete brake job yesterday. Turned rotors, new pads and bleed the brakes. Now my driver side will not turn at all. I can step on it and its locked. The passender side is fine. Now if I open the bleeder and bleed the brake again it will be fine until I close the bleeder and pump them up and it locks again. When I pushed the piston back for the new pads it seemed to move freely. Did I do something wrong or have I found a bad caliper????
Brian Felts
Old Nov 14, 2003 | 01:15 PM
Morley's Avatar
Bad caliper or hose.
Old Nov 14, 2003 | 01:24 PM
kevinc's Avatar
Car: 1982 Z28
Morley said it, there are failure modes for hoses that can cause this. If the rubber hose has collapsed internally, it will create a one-way valve where pressurized fluid can pass thru but not be fully released.
On the caliper side, a piston sticking in the bore will have the same effect.
If the hoses are old, it's a great time to replace them. Either a new OEM-type set, or an aftermarket braided-stainless Teflon set from Earl's or Russell will do the job.
Old Nov 14, 2003 | 02:19 PM
Morley's Avatar
I wouldn't reccommend Russell, they make their ends from brass and several people have had them crack and break off. Earl's make theirs from stainless steel and are much more durable. Also about the same price as Russell.
Old Nov 14, 2003 | 02:25 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
bad brake line or sticky caliper piston..
good news though... autozone can get you a new caliper for only $11.99.... calipers for these cars (non 1LE) are cheap.
and its probly past time for you to have new hoses anyway
Old Nov 14, 2003 | 04:36 PM
kevinc's Avatar
Car: 1982 Z28
There must be an echo in here.
Old Nov 14, 2003 | 04:48 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Russell has actually changed their lines and now uses steel fittings rather than brass. Still, after my experience with them I won't ever use Russell again. Earl's or Goodridge are the top choices for brake lines.
Old Nov 14, 2003 | 04:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
yeap.
for some strange reason though, people feel more secure about a answer when several people come to the same conclusion.. *shrug*
Old Nov 14, 2003 | 05:08 PM
Good news about the caliper price.........do they also stock the brake line or will they have to order both.
Brian
Old Nov 14, 2003 | 05:19 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Brian
the SS lines are a aftermarket item, so thats kinda hit and miss...
they should have regular rubber brake lines in stock though.
Old Nov 14, 2003 | 07:09 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Most places will not have to order any of the parts, but some may. I just happened to get lucky, I suppose.
Old Nov 14, 2003 | 08:04 PM
Well cross your fingers for me. I may need it.
Brian
dbrochard
Sep 19, 2015 08:13 PM
rb85TA
26
Sep 14, 2015 10:29 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
