rear end swap question; Need help
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
Ok, so i have an 86 iroc with a standard 3.23 rear end with drum brakes. I want a posi rear with disk brakes. Is there a certain year that can bolt up to my car no problem and is it worth going to disk in the rear. What problems will i encounter and what do i need to do to make a successful swap. Any advice will be appreciated. thanks
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Welcome to the site.
Here's a couple of options:
1. Replace the rear with a posi disc rear from a '90-'02 F-body. The will all bolt in but you will have issues with the e-brake cables for the '98-up rears and the '93-up rears are a bit wider than the 3rd gens. This will be your cheapest option as you can get a whole rear for $200-300 and a gear install will cost that.
2. Keep your 3.23 and swap it over to discs. You will need disc backing plates and a rear disc setup from a '89-97 car, and install a take-off posi from SLP ($100).
Search a little and you'll get a load of info on the topic.
Ed
Ed
Car: 1986 Iroc-z
thanks guys, that the fastest i have ever seen any one reply.
One thing i wasnt really clear on in my question was is it worth the money to change from a drum rear to a disk rear. are the advantages that good.
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Fellas, wasn't there two different rear-ends used on our thirdgens? I read somewhere that one was built in Australia and significantly weaker? When looking for a replacement how do you tell the two apart? Thanks
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Thanks EDE, do you know where we can get a picture or description to tell them apart? Does the 10 bolt / 9bolt refer to bolts on the cover? I'm not sure what to look for to find the more desireable rear-ends. Sorry if I've taken over this post, but I think this will help a lot of us that are new to modding the thirdgen.
Yup you hit it right on the head.
9 bolt has 9 bolts and a circular flatish cover
10 bolt has 10 bolts and a circular flatish cover
I'm sure you won't run into a Dana 44 but...
I can't remember how many bolts, but the cover is not flat by any stretch of the means. its got a big hump on one side.
Car: 92 firebird
Engine: A small block something?
Originally posted by joshwilson3
I have a 10 bolt and the cover has a big bump on the left side. Is that what you were talking about?
If I found a 9 bolt differential, could I just pop that in? Also, if I go to the local junk yard, how can I tell what kind of gears and if it is a posi or not by looking at it? Are there numbers or anything on the axil? I don't wanna do alot of work to figure out what the type of axil it is.
if you can get a 9 bolt do it immediatly gears are a hard thing to find for tho .Yes if will pop in but if its disc then you will have problems with the e-brake cables.when buying a rearend from a yard put it on milk crates,jackstands,ect and spin the axel if the both spin the same way its a limited slip or "posi" if they dont then its open or "junk" unless its cheap and you have a posi unit for it.
As for telling what gear it is. Spin the axel one tim and count how many times the yoke spins.If it spins 3 1/2 times its 3.42 if 3 3/4 its 3.73 , 3 its 3.08 ect . it you lookin to make gobs of power out of this car i dont recomend a 10 bolt
i am still infamiliar with these stupid rearends too...
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
