sway bar problem
Old Nov 30, 2003 | 10:00 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
sway bar problem
Alright, i'm changing the oil in my car, and i look over to the passengers side and what do i see, the sway bar is unattached on that side. The mount and bracket are completely gone. Is that uncommon? I have no idea how long its been like that, but i think i would have noticed that the last time i changed my oil three thousand miles ago.
How hard is it to install a new sway bar? Im thinkin about getting the one from spohn. Good choice?
Questions and comments appreciated.
Ken
Old Nov 30, 2003 | 10:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
If your swaybar has been taken off before, its easy. If not, them end links can be a PITA. The frame mounts are easy to come off.
Being and RS, you could get the stock 36/24 Z28/Iroc setup, it would be cheaper, and an upgrade itself.
Old Dec 1, 2003 | 12:03 AM
MdFormula350's Avatar
yeah sounds like a good time to upgrade to bigger one and get some new energy suspension endlinks and some tds front greasable bushings.
might want to check to see if u have a wonderbar right under the sway bar, good time to get one also.
Old Dec 1, 2003 | 12:09 AM
cali92RS's Avatar
Car: White KSwisses
Unless the car came with a wonderbar from the factory, i dont have one.
Im not good with suspensions, what does a wonderbar do and where does it go?
Ken
Old Dec 1, 2003 | 06:11 AM
Dale's Avatar
Engine: 350 S-TPI
an RS would not have come stock with a wonderbar. It mounts to the same points as the swaybar. It stiffens the front of the frame rails, and keeps them from twisting during use.
Old Dec 1, 2003 | 07:09 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Mounts on the same bolt as the swaybar (doesn't replace it though), and is just a straight bar between the frame rails to stiffen things up a bit. I put one in a few days ago, and I could feel the differance a little.
Old Dec 1, 2003 | 12:17 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Hey Ken
If you're interested I have a friends 36mm factory bar w/ poly end links. I can try to hook you up with him.
You can get a factory Wonder bar for $10 or less at Pick-your-part. It bolts up with the swaybar and ties the front frame rails together.
Old Dec 1, 2003 | 03:16 PM
cali92RS's Avatar
Car: White KSwisses
Thanks Jon, but I got a buddy who works at a bone yard here and he has a Z that was wrecked so i might just pick that car clean.
Hey are u going to the Dec. 6 meeting or the dinner on the 13th (its on the 13th right?)
Ken
Old Dec 1, 2003 | 09:03 PM
Jon92TA's Avatar
I won't make the meeting but the dinner at Knotts does sound good. Just waiting to hear the latest plan.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
