Torque Arm?
Old Dec 3, 2003 | 01:53 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Torque Arm?
id like to put some money into my rear suspension. LCAs, Reloc kit, PHB and an air bag are a must. my car will be in the 13s, and im wondering is an aftermarket torque arm really worth the money? or is my car not puttin out enough power yet to really take advantage of one. im asking because i dont want to spend 300-400 dollars on a torque arm to get nuthin from it. if the strength of the factory one is the issue, edelbrock sells a non adjustable tubular one for 200 that might better suit me. id like to hear some facts on this
Old Dec 3, 2003 | 02:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"Strength" as such isn't the issue. The problem with the stock one is that it flexes; and like any other suspension part that unintentionally stores energy, it makes the whole system act unpredictably. The harder the car tries to hook up, the more the torque arm will bend; the more it will alow other suspension parts to move out of their ideal position; and the harder it will be to make it behave the same every time.
I'd recommend trying the other things, and see if they make the car stable and predictable enough for you. If they don't, then revisit the torque arm possibility. It's not something that depends on the other parts, or that those other things depend on either. You can always add it later.
Old Dec 3, 2003 | 02:39 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Read this thread
https://www.thirdgen.org/techbb2/sho...hreadid=212376
Old Dec 3, 2003 | 04:29 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
good to know i guess ill do the other stuff first then see whre im at
Old Dec 5, 2003 | 08:38 AM
MdFormula350's Avatar
yeah i total agree with RB83L69
flex was one thing i could feel with the stock stuff and after changing everything in the rear suspension flex it basically total gone.
the rear end basically just goes up and down now instead of wheel hopping and side to side as well.
i definitely put more power to the ground now, but still my tires cant hold wot in drive from a stop, so i am looking into drag radials for near years racing.
Old Dec 5, 2003 | 06:40 PM
10.90streetcar's Avatar
Yeah, My last 7 passes with the flimsy stamped steel piece was unpredictable.
1.446
1.444
1.442
1.449
1.442
1.440
1.448
Old Dec 5, 2003 | 08:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
10.90 streetcar.....yours is a freak car...lol
good times....not sure about that torque arm....i would like to try different pinion angles, that's the only thing i could see you wanting one for .....might pick up time, might not do a thing. but congrats on your times.
Old Dec 5, 2003 | 09:47 PM
laiky's Avatar
I think the large soft slicks are responsible for the short times. In 10.90's case the FLEXING might just increase traction. If it absorbs the shock from the launch it might work better in his case. I really don't know. but i don't think weight transfer is as much of an issue with the drag tires. My personal interest in upgrading my torque arm if from handling and predicatability standpoint
Old Dec 6, 2003 | 11:12 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
1.446
1.444
1.442
1.449
1.442
1.440
1.448
LOL, I agree!! Tell that to all the guys I put on the trailer this year with my flexible non-consistent torque arm. Believe me, all the money I took home this year coulda bought some really nice arms, but if it aint broke why fix it. At the world series and nationals with the DA changing I had either a 13.05 or .06 dial for three days straight. Way inconsistent IMO
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
