90-92 Ten-Bolt PBR to Pre-89 Ten-bolt With Discs
Old Dec 10, 2003 | 11:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Anyone completed this swap (I'm talking about swapping only the brakes, not the entire rear end)? If so, did the newer car have shims in place? Any problems or shortcuts?
JamesC
Old Dec 10, 2003 | 01:43 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
I dont understand.
I was curious as to why you were looking to do this. It seems most people on this boards try to do exactly the opposite of what youre trying to do. From what Ive understood, the Delco Moraine brakes on the pre-89 rears were junk and hardly worked properly without a rebuild, plus you'd be downsizing your rotors. Feel free to explain your reasoning. Thanks, Efrain.
Old Dec 10, 2003 | 02:39 PM
JamesC's Avatar
I want to retro fit the PBR's with 12-inch rotors to an 85 IROC with the D/M brakes without swapping rear ends.
JamesC
Old Dec 10, 2003 | 03:02 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here's a GREAT how-to from GMHTP on how they switched to the PBR disc brakes from Baer on their project car's older style disc rearend. All PBRs will be about the same so here's what you'd have to do:
http://www.gmhightechperformance.com...mht_baerfacts/
Ed
Old Dec 10, 2003 | 07:05 PM
OMINOUS_87's Avatar
ebmiller88
Great link!
My question to you now would be this, If I have an 86 or so 10bolt with drums and a 91 10bolt with PBR, all I have to do Is swap parts from the mounting plate out?
thankx
Old Dec 10, 2003 | 08:40 PM
ebmiller88's Avatar
And the e-brake cables and the hard lines (unless you mod your own), but essentially , yes. There would be a bit of modding of the drum axle flanges but it's not that bad.
Ed
Old Dec 10, 2003 | 09:18 PM
OMINOUS_87's Avatar
Any further details?
So its not a bolt and go?
Old Dec 10, 2003 | 09:20 PM
OMINOUS_87's Avatar
I got the ebrake stuff, and axle hardlines, you arent talking about the hardlines on the unibody are you?
Old Dec 10, 2003 | 10:22 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: 90-92 Ten-Bolt PBR to Pre-89 Ten-bolt With Discs
JamesC
Should be a straight swap. You have to swap the brake hardline on the rear too. The PBR rears used a different bore size MC then the iron rears did.
Old Dec 10, 2003 | 10:24 PM
Nope. You'll have to hack the top of the flange off and drill some new bolt holes.
Old Dec 11, 2003 | 05:25 AM
ebmiller88's Avatar
Ominous, the drum flange mod is covered in the LS1 brake upgrade tech article section on the homepage. Here's the link with great pics of hos to chop the drum flange:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Ed
Old Dec 11, 2003 | 10:07 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
he already has a disc brake rear. not a drum rear. so cutting and re-drilling should not be necessary.
he's going from the sucky rear 10.5 discs to the PBR type. not drum to PBR.
Old Dec 11, 2003 | 04:34 PM
ebmiller88's Avatar
Ominous 87
I responded to his question, not the thread topic.
Ed
Old Dec 11, 2003 | 05:05 PM
Car: 1988 IROC-Z
i totally read over that.
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
KO1
16
Oct 15, 2015 05:00 PM
indygene
Sep 26, 2015 11:21 AM
