88 Fromula 350 WS6 or not
Old Dec 14, 2003 | 03:33 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
I have a 88 Formula 350 (no rpo codes) parts car and it has a good steering box and mine leaks a little right now. But I wondering how I could tell if it was WS6 or not? I have heard that they come with better steering boxs.
Right now I know that it has 4 wheel disc breaks and a 3.27 B-W rearend.
Old Dec 14, 2003 | 03:49 PM
Chet's Avatar
Car: GTA
All formulas have the WS6 suspension.
Old Dec 14, 2003 | 04:15 PM
ss85tadude's Avatar
Car: 85 Trans Am
Sweet. So are the steering boxs that much better?
Old Dec 14, 2003 | 07:12 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
As long as it came with the 16" wheels.. Yup
Kat
Old Dec 15, 2003 | 07:05 AM
ss85tadude's Avatar
Car: 85 Trans Am
Well since it has AR outlaw 1's that are 15" I do not know what size it came with originally. How can I find out?
Mabye inside the door jam? I will have to look when I get home
Old Dec 15, 2003 | 07:46 AM
Ram Air TTA's Avatar
Car: 1989 Turbo Trans Am
Engine: 3.8L Turbo V6
Transmission: 2004r
ss85tadude,
To my knowledge all 87-92 formula's came with 16x8 wheels & 245/50/16 stock. And as was previously posted all had the ws6 suspension standard. Trans Am GTA & Formula's also all had the quick ratio 12/1 steering boxes. Hope this helps.
Old Dec 15, 2003 | 08:16 AM
ss85tadude's Avatar
Car: 85 Trans Am
So do think the steering box would be better than mine (besides the fact that it don't leak)?
Old Dec 15, 2003 | 01:28 PM
Transmission: 2004r
Well that depends. You will have to research out what suspension option your car originaly came with. In 1985 the 16" wheels were optional not standard with the ws6 package. Remember it was only the first year they were available as an RPO. But to my knowledge all that were optioned with the 16"wheels had the quick ratio steering box. If yours didn't come with 16" wheels that is not to say that you don't have the good box, but you will have to reseach a little harder to find out. I think that all ws6 cars had the fast box but I'm not sure. Hope this helps.
Old Dec 15, 2003 | 08:14 PM
ss85tadude's Avatar
Car: 85 Trans Am
What exactly is the diff in a standard box and a quick ratio box?
And my car came originally with 15" T/A wheels
Old Dec 15, 2003 | 10:51 PM
Transmission: 2004r
If I remember right the standard steering box has a 15/1 ratio which is the standard f-body box. Also the fast ratio box had shorter steering stops to compensate for the larger tires.
Old Dec 16, 2003 | 07:00 AM
ss85tadude's Avatar
Car: 85 Trans Am
So will this make my car handle better?
I am also planning on installing a wonderbar.
Old Dec 16, 2003 | 08:13 AM
Transmission: 2004r
Well it make it steer quicker with less turns lock to lock. Installing the wonderbar is a good inexpensive move and will improve handeling by stiffening the steering box area for less deflection. I would say the next move would be subframe connectors (weld in style--- see spohn website) and then look at suspension bushings and decide how far you want to go from there (mild--poly bushings and boxing control arms or wild-- trust me too much to list) Best thing I can tell you is make sure your car is at least safe, then check out some suspension sites and have a blast. My personal fav is spohn engineering (see above links) Good luck
Vojtush31
Oct 11, 2015 01:07 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dbrochard
Sep 7, 2015 09:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
