Copper crush washers
Old Dec 14, 2003 | 09:12 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
The copper crush washers on the front calipers... is one supposed to have a different I.D. than the other, and if so, which one goes between the hose fitting and the caliper. (I did a search and couldn't find anything about different I.D.s.)
Old Dec 16, 2003 | 01:12 AM
No one knows anything about the copper crush washers?
Old Dec 16, 2003 | 02:18 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have them on my car
I have used washers that were the same and one that was a wee bit smaller on the caliper side. I get them at AutoZone, they have a big tray full behind the counter. Just get the ones that best fit your banjo bolt. As you stated, I put the one with the smaller I.D. on the caliper side of the fitting.
Ed
Old Dec 16, 2003 | 02:23 AM
Thanks. Any particular reason, or you just decided that way fit best?
It was funny when I started to read your reply I read, "I have used washers..." I was going to say you should probably spring for some new ones.
Old Dec 17, 2003 | 01:41 AM
ebmiller88's Avatar
I just compared them to the ones I took off, no big thing really. I don't use one those that look too "thin", I like the thicker style.
Ed
Old Dec 17, 2003 | 01:50 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I've had to use them on an Grand Voyager once while I was doing a brake swap. Never dove into my brakes far enough to know if I even have them. However, I like the thicker ones a little better. If you attempt to re-use the washer, stop wasting your time because you cant. Just go out and get a new one. Plus, try not to screw it up the first time :P
Old Dec 17, 2003 | 07:43 AM
25THRSS's Avatar
I reused all of mine when I replaced my hoses and everything is perfect.
Old Dec 17, 2003 | 10:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Anneal them with a torch and you can use them again just fine.
Fireslash
Apr 11, 2016 06:43 PM
gord327
Sep 29, 2015 10:18 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
hdis2002
Sep 8, 2015 02:52 PM
Saxondale
Sep 7, 2015 06:11 PM
