Clunk Clunk
Old Jan 3, 2004 | 04:43 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
Clunk Clunk
If i hold one of my rear tires and pull back and forth it makes a clunking noise, and when i go over a bump, it makes the same noise. The rear end is moving when i push and pull on it. I checked the lug nuts for tightness, and they are. What could be making it move like that?
Old Jan 3, 2004 | 06:00 PM
Spdfrk1990's Avatar
The panhard bar bushings could be shot specially if it does it while driving. Mines does that also but i have a new panhard bar just havnt installed it yet.
Old Jan 3, 2004 | 06:06 PM
MdFormula350's Avatar
yeah that movement might be due to the panahard bar, or maybe that side's axle is moving in and out, or even both. but if the whole rear end is moving definitely look into the panhard bar.
Old Jan 3, 2004 | 07:34 PM
Transmission: autos
sould someone show me a pic of that?
Transmission: autos
also is it unsafe?
Old Jan 3, 2004 | 08:06 PM
Spdfrk1990's Avatar
look on this page at the pic of the rear end. Its the bar that goes from the rear axel over to the body goin from left to right.Its black
https://www.thirdgen.org/techbb2/sho...ht=panhard+bar
Old Jan 3, 2004 | 08:13 PM
Transmission: autos
so its this bar? anyway to tell if it has bad bushings? is it unsafe to drive it the way it is?
Old Jan 3, 2004 | 08:14 PM
Transmission: autos
opps forgot the pic
Old Jan 3, 2004 | 08:46 PM
Spdfrk1990's Avatar
Yes its that bar and its really not unsafe unless ur doin alot of fast cornering. U could tell if it was bad by moving the rear end from side to side and seeing play in it
Old Jan 4, 2004 | 01:58 AM
BrobertsANigger's Avatar
Agood here,
Its not the panhard, its your axles that have play in them near the carrier pin and axle c-clip area. As the carrier pin ages, more play develops in the floating c-clip axle design and the lateral knock becomes more previlant. Even with a new carrier/carrier pin, you will still get a lateral knock or clunck on a 10-bolt c-clip style rearend.
Dean- going, going, gone......again
Old Jan 4, 2004 | 08:04 AM
Spdfrk1990's Avatar
My rear clunks i have a 9 bolt and i know its not the axels. When u go over bumps and things it will do it.
Old Jan 4, 2004 | 08:58 AM
Transmission: autos
well im gonna go check it out in a minute, i hope its the panhard bar, not what agood said. I have a extra panhard bar here, the v6 and v8 ones are the same right?
Old Jan 4, 2004 | 09:55 AM
Transmission: autos
the rear end is moving from side to side, atleast from what i can tell, it moves the same amount with i pull on either tire. Still need to know if the panhard bar is interchangeable
Old Jan 4, 2004 | 02:18 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yes they are interchangeable. Even a 4th gen one would work, V6 or V8 - they are all the same.
Old Jan 4, 2004 | 02:24 PM
Transmission: autos
i tightened it up and it doesnt do it anymore, that was a easy fix
Old Jan 4, 2004 | 02:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
My panhard rod made a lot of noises but that is because I had the rod end on the wrong side. I took it off and flipped it around and everything went away.
Old Jan 4, 2004 | 03:04 PM
JPrevost's Avatar
Car: 91 Red Sled
It'll be back. When you tightened it up you're only holding the bushing with a clasp force that is completely normal to the actual forces being applied to the bushing. Trust me, it'll work for a while but will need to be tightened up every few thousand miles or less depending on driving style/conditions. Tight tolerances isn't one of the big 3's goals in auto making. The just do it cheaper than everone else and hide stuff like this with crappy bushings. At least change the bushings out with new. Also be certain that the bolt being used is a close tolerance with the sleeve in the bushing! I'd replace the bolts if they're badly rusted which many of them are. Right now I've got a loose LCA because when I installed the relocation brackets, Spohn's kit only came with 4 bolts to replace the bolts on the rear end side, not on the body side. It was really pathetic how rusted up the bolts got and how much material disappeared.
Old Jan 4, 2004 | 03:05 PM
z_power's Avatar
Car: '89 GTA
Engine: a bunch of pieces
Transmission: still there - very stockish TH700
Where is it better to place a rod-end (if using bar with one end bushed and another "joint-type")? Attached to body or better to the axle?
Old Jan 4, 2004 | 04:06 PM
Transmission: autos
my bolt isnt rust, and i know its only a temp fix, but i only drive it on nice days. Which since its january, thats not often, Well unless u live in a warm place, or have crazy temp changes like VA.
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
