60 ft times
Old Jan 6, 2004 | 12:48 PM
conlinj's Avatar
60 ft times
What are some of your 60ft times, with a stock or near stock (bolt-ons) motor and modded suspension? Please post the times and what mods to your suspension you have done
Old Jan 6, 2004 | 01:17 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
2.8 V6 with no mods to anything.
2.387 60'
Old Jan 6, 2004 | 04:27 PM
conlinj's Avatar
any more? i'm actually looking for cars that have modded the suspension alot but are still running a mostly stock motor, not all stock setups.
Thanks,
Jim
Old Jan 6, 2004 | 07:02 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
With a mostly stock thirdgen you really wont need much in terms of suspension mods to 60ft well,other than a set of drag radials unless by bolt on your talking about nitrous, supercharger, or turbo.
I know my car is not what your looking for though it is not very far from stock either.It's a 3.8 V6 with TH400 trans and 3.08 geared 12 Bolt.
Up front I have a PA Racing tubular k-member and a-arms with Koni struts and QA-1 coilover springs(14"/130#).Out back I have Hotchkis panhard rod and trailing arms with KYB struts and stock springs with air bags in them(5#L/25#R).Torque arm is a Jegster which I really like.
I run 26x11.5x16 ET Streets and consistantly 60ft in the 1.47-1.49 range(1.47 best)
HTH,
Steve
Old Jan 6, 2004 | 07:48 PM
Gus_Mahn's Avatar
I also have a TTA. Mine runs 1.89-1.95 60' times on BFG Comp TA's. Suspension is totally stock. The car has a chip, test pipe, open air cleaner, and a mild stall. Never had slicks on it.
Old Jan 6, 2004 | 08:59 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Car is in signature. Best 60' ever was a 1.89.
Usually runs 1.95-2.05 depending on how good track prep is
Old Jan 7, 2004 | 09:28 AM
conlinj's Avatar
Thanks alot guys, where the koni/qa1's a direct bolt in or what mods did you have to do?
Old Jan 7, 2004 | 05:30 PM
MdFormula350's Avatar
times in sig and mods in sig. i need drag radials.
Old Jan 7, 2004 | 08:31 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
The Koni's are stock replacements from Jegs or Summit and the coilover setup was from PA Racing.It originally came with Afco springs but scince I was not happy with the rate/length I ordered the QA-1 springs from Jegs or Summit(I forget which).
I will add that though the Koni's are good struts,IMHO they are not the best struts for drag racing and am switching to Competition Engeneering or Lakewood non-adjustable 90/10 struts and 50/50 rear shocks for 2004 after seeing how they operated last year.If I were more concerned with street and handling I'd make the compromise and stick with the Koni's but I'd rather go for 1.3x 60fts
Steve
Old Jan 7, 2004 | 08:34 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Good, gimme your old Koni's Steve
Kat
Old Jan 8, 2004 | 05:56 AM
conlinj's Avatar
I am installing the Comp Engineering c2700 adjustable rear shocks when i put my rear in, i've heard the koni spa1 drag shocks are better then the 90/10 shocks but at 189 a piece that's a little rich for my blood. I may go lakewood 70/30 for the front since the car does see some street use. I wish they made adjustable front shocks like they do rears. Wouldn't it be nice to go from stock to 70/30 to 90/10 depending on the what you need for street or how the track was prepared?
Old Jan 8, 2004 | 03:20 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
They do,the Koni struts I have are adjustable.
Kat I'll let you know when I change em,dont know exactly when that'll be though(hopefully sometime this spring).
Steve
Old Jan 8, 2004 | 07:03 PM
conlinj's Avatar
I meant adjustable to 90/10 if your koni's adjusted to that right now why switch to comp's or lakewoods
Old Jan 8, 2004 | 10:39 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Your right,they do not adjust all the way or at least I dont think they perform like they do.In the end the koni's arent made for drag racing,more of a street or road course strut.
I'm changing them cause I'm not happy with them.I want a lighter single rate 90/10 strut made for drag racing that wont unload the rear tires when they come back down like the koni's do.
Steve
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
