Rear end moves side to side..
Old Feb 9, 2004 | 01:46 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I hit a turn and i can hear it clunk to one side.
I get out and kick it and it clearly moves side to side.
Its freaking me out. I think the panhard bar is causing it?
Old Feb 9, 2004 | 05:00 AM
ede's Avatar
ede
you ought to get under the car and take a look, anythnig bent ot broke ought to stand out pretty clearly.
Old Feb 9, 2004 | 07:46 AM
MdFormula350's Avatar
easy side to side action i would definitely look at the panhard bar area.
the top bracket could be loose that would be my guess off hand, missing a bolt or something it would most likely fall down after a while.
Old Feb 9, 2004 | 12:13 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Yes, definatly get under it and find out. Dont drive it.
Old Feb 9, 2004 | 03:19 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
maybe look at your panard bars bushings...cause if it was loose would it be hanging or your tires would be rubing on the body. Are you sure its moving and that the sound is not coming from the front end...also cheak all your stabalizer bar link ends and straps that tie them to the cars body frt and rear if you got both. (i forget to look at your sig to see what car you drove)
Old Jul 2, 2004 | 10:39 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Just a follow up for people searching;
It was the panhard bar. Apparently they require a HUGE torque on the bolt, like more than 80Ft Lbs if I remember correctly. It may have well been over 100Ft Lbs.
If the panhard bolt isnt that tight, the rear end will go "clunk" when you go around corners. if you push the rear of the car side to side it will wobble and go "clunk clunk" also. Simply tightening that bolt fixed it up.
Old Jul 2, 2004 | 10:55 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
95 lbs/ft iirc
Old Jul 2, 2004 | 11:33 PM
83 Crossfire TA's Avatar
Heh, I thought I was chasing the same deal but when I jacked the back of the car up I found that the driver’s side tire spun almost freely… I’m guessing I’ve got a broken axle, I’ll know when I pull the cover.
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
