Suspension measurement needed to see if i have a drop on my car
Old Feb 10, 2004 | 02:42 PM
91NiteRida''s Avatar
Car: 1991 Camaro
Hi,
I was wondering if someone with a 91 camaro,305,and 16" rims can get a measurement for me.I need a measurement from the center of the fender to the ground...Im not too sure if i have a drop or not.Here is a picture of my ride.
Old Feb 10, 2004 | 06:44 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
From the pics I would say it might be lowered a little. Have you gotten up under the back to see what the springs look like? The stock ones are not coated while most aftermarket ones are. I have the pro-kit and you can tell they are not stock.
Old Feb 10, 2004 | 07:12 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
if it is lowered, raise it back up! im totaly against lowering the f bodies. doesnt look lowered to me. see if you got some nice rusty springs under there. if you do then they are problebly stock springs. you know, they could be stock springs that are just sagging.
Old Feb 10, 2004 | 08:40 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If they are black and have a thick coating of funk on it with various paper tags atached to them then they are stock. Aftermarket ones are usually coated a certian color and have a lot thicker coils (about .25 and larger).
Kontrax
You really don't like lowered 3rd gens? With stock wheels I can see that but even with aftermarket ones? A little lowering and some new wheels makes these cars look perfect like they were destined to have big rubber.
Attached Thumbnails Suspension measurement needed to see if i have a drop on my car-dsc00044.jpg
Old Feb 10, 2004 | 10:06 PM
nolanr0413's Avatar
Car: Trans am
heres mine, with sportlines, but i have a chrysler rear end so the rear is high cause the axle tubes are bigger.
Old Feb 10, 2004 | 10:14 PM
nolanr0413's Avatar
Car: Trans am
sorry forgot the pic
Attached Thumbnails Suspension measurement needed to see if i have a drop on my car-lowered-trans-am.jpg
Old Feb 11, 2004 | 12:08 AM
Car: 1991 Camaro
Thanks for all the help...I think i have sagging springs then because i have black coils under the camaro...I plan on getting 18" Irocs with a 1" drop all around to give me the stance i want.Thanks for all the help once again..She is getting painted tomorrow
Old Feb 11, 2004 | 02:52 PM
Kontrax's Avatar
Car: 86 Camaro
lowering the f body doent do anytthing except cause problems. sure you might gain handling a bit, but now you have more stress on the front end. also, if you have roads like i do up here, you put your car at greater risk of damage. and think about it, tow guys have a hard enough time getting out cars on flat beds and tow hitches as it is, how the hell are they going to do it with a drop?! but if you like lowering it, go for it. just not my thing. i actually lifted my cars rear a few inches.
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Kaweh
Aug 9, 2015 02:54 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
