propportioning valve
Old Feb 15, 2004 | 11:10 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
I'm clueless here. I just bought a 4th gen rear end to put under my 82 trans am. I read the tech article on installing it, and the article says I need a proportioning valve. why is this?
also, when i get one, where do i get all of these fittings to install it?
three (3) 3/16ths inverted flare tubing nuts
two (2) ¼ inverted flare tubing nuts
one (1) 3/16ths inverted flare female "T" fitting
two (2) 3/16ths-inverted-male-flare-to-1/4-inverted-female-flare adapters
I read the article on installing the proportioning valve, so it seems like i can do it myself, but is this something i really NEED? and how expensive is this all going to be?
Old Feb 15, 2004 | 11:34 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
no 3rd gen prop. valve can operate the rear brakes of a 4th gen rear end like it supoosed to, so you'd need a new one.
as for the brake fittings, im sure some auto parts store/website will carry them. try earls
Old Feb 16, 2004 | 01:42 AM
Car: 1982 Trans Am
Engine: 383 chevy
thanks.... anybody else?
Old Feb 16, 2004 | 09:27 AM
Car: 1982 Trans Am
Engine: 383 chevy
anybody else?
Old Feb 16, 2004 | 11:01 AM
ede's Avatar
ede
you need a flat sided machined looking aluminum PV from a thirdgen, i'd guess a 4th gen PV would also work. all the lines should bolt right up with no problem
Old Feb 16, 2004 | 02:36 PM
Car: 1982 Trans Am
Engine: 383 chevy
could i get this at a parts house somewhere (advance, kragen, shuck's...) also, WHERE is it?
Old Feb 16, 2004 | 07:40 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
You can pick up the fittings at a Pep Boys or NAPA store. I've had spotty luck getting stuff like that at AutoZone or Advance Auto. Seems like they always have room for neon lights and fart pipes, though.
Old Feb 16, 2004 | 08:15 PM
Car: 1982 Trans Am
Engine: 383 chevy
f**kers. I'll try NAPA. thanks man.
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
