i need spring help!!!!
Old Feb 19, 2004 | 01:11 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
alright guys, i am doing a v6-v8 swap in the end of the summer and i need to know what kind of springs to use. the car is a sport coupe camaro so it doesn't have ground effects. i am going with 15" 'fatties and skinnies' for wheels and tires and i would like to give it a mild rake. lowering the front end ever so slightly. here is the biggest deal. i want the car to have good street manners, but don't necessarily need to have great cornering capabilities. basically, i want a spring that will have the same rate as the stock spring with a lower ride height and cutting the springs is not an option. what are my options?
Old Feb 19, 2004 | 09:50 PM
mw66nova's Avatar
Engine: 7.0L
alright, i know that the guys on here are mostly into road racing or handling, but i really need to know this...would a set of used iroc springs work for what i need? thirdgenresources sells them for $75 for the set of four.
Old Feb 20, 2004 | 12:33 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
IROC or WS6 springs would to the trick. They won't lower the car much but they will help. Look at BMR and Hotchkis springs. They only lower the car 1". After than you have the pro kit (roughly 1.5") and even lower are sportilines and intrax (2"+).
Old Feb 20, 2004 | 02:55 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i purchased a set of ws6 springs about three months ago. problem, my car is a v6. went to have the camber fixed and was informed of the part number error. they have been on my car, but are in new condition (three months use) if you want the fronts i can sell em to ya. PM me
Old Feb 20, 2004 | 04:02 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Moog makes a good set of replacement springs for our cars, the part numbers were posted not too long ago, do a search and see what you get.
Ed
Old Feb 20, 2004 | 06:41 AM
mw66nova's Avatar
Engine: 7.0L
does anyone make a spring that is street/strip? something with a slightly softer spring rate, or am i going to be better off keeping the v6 springs in it. that would lower the front a little. the last car i had, i kept the v6 springs in it, but going around a turn to fast ended me in a ditch after going through two walls. should i sacrifice the corning that much and just learn to drive my car better?(ie, don't act like a road racer in a drag car) i am looking for more weight transfer but i don't want to go with an all out drag spring....
Old Feb 20, 2004 | 07:44 AM
MCas7's Avatar
For what it's worth, if you leave the stock v6 springs in there, they will do what you want. I have heard of a lot of guys (especially drag racers) leaving the stock V6 springs in there because of the low spring rate. If you put V8 spring in it, they will bring the car to the stock ride height. Moroso makes front drag springs if you wanted to go that route.
Old Feb 20, 2004 | 08:16 AM
mw66nova's Avatar
Engine: 7.0L
yeah, i know, my dad has some sitting in his garage, but they are not for street use, and after the accident, i know why, they are just too light, i think that i may just leave the v6 springs in it.
Old Feb 20, 2004 | 09:19 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
my sport coupe was swapped a v8 in place of the original v6, and still has the v6 springs up front.
i don't like how the car handles in daily driving. i'm going with stock replacement 1985 iroc springs once the nice weather stays.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
