higher sping rates but stock height?
Ok Im looking for some companies that make a higher spring rate with the stock ride height. I have some heavy stereo equpment sitting on the rear wheels and it is making the rear springs sag a bit. I am running 18" Z06 wheels on the back and I realy dont think the car needs to be lowered, plus I worried about rubbing with the 285's. If anyone has any ideas I would greatly appriciate it!! Thanks
Jim
Jim
I do have the moog springs back there, and even they are starting to sag a little. I have about 140-160 lbs sitting in the "pit" and on the rear shelf. Thanks for the reply.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Have you tried replacing the rear spring isolators? If they are orig, they are prolly flattened out a bit. I hear the 4th gen ones are taller and might raise the rear up enough for you.
I might try the 4th gen's I replaced them with the 3rd gen replacements. Doesn't Energy suspension make sping isolaters? I might try those. I take it by the responses no one makes a stiffer stock height spring? Thanks for the replys.
Jim
Jim
Car: 89 formula
Engine: 383
Maybe you could use someting like this http://www.budzter.com/
Thanks for the replys. The spacers look interesting but I like the idea of the WS6 Springs. Ok well at least now I have a few different options. Thanks again for your help.
Jim
Jim
Ok, after I saw the eibach spring rates posted I'm thinking that the pro kit might pair up well with the koni sports. I checked my tire height and available space and I think I can afford to drop the car 1". Will that combination control the extra weight in the back well or will I have problems? Thanks again. I really don't want to drop close to 1K on this and have bottoming and rubbing problems.
Genopsyde
Oct 7, 2015 08:35 PM
sailtexas186548
Aug 26, 2015 03:32 PM
