Front Tower Brace
Old Mar 5, 2004 | 09:33 PM
noarch's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Front Tower Brace
I was wondering if anyone out there uses a 305 TBI with a front tower brace. I've seen it done with an Open Element Filter, but since the only braces I've seen say TPI, I wanted to make sure it works with the filter before I spend $160+ on something that doesn't fit.
Old Mar 5, 2004 | 09:44 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you can find a Jamex STB somewhere, it fits great. I don't think the TPI braces will clear your air cleaner.
Ed
Old Mar 5, 2004 | 09:46 PM
25THRSS's Avatar
I like the edelbrock one
Old Mar 5, 2004 | 09:55 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Edelbrock for me too.
Old Mar 5, 2004 | 09:59 PM
Car: 89 RS
Here you go
1987-92 Camaro/Firebird V8 w/T.B.I. (fits vehicles with A/C compressor on passenger side) ....#5227
Edelbrock Strut Tower Braces
Old Mar 7, 2004 | 11:46 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Unfortunately I have edelbrock's triangular air cleaner (looks great), but there is no way a stb would fit on my car
Old Mar 7, 2004 | 10:45 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
The guy from JEGS told me it would fit up to a 17" or 18" diameter air cleaner
Old Mar 7, 2004 | 11:21 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
chcek thsi otu
Old Mar 7, 2004 | 11:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Any air cleaner under 14X3 should work just fine. I like my Edelbrock TBI STB a lot.
Old Mar 10, 2004 | 12:13 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I have the same 3pt Edelbrock that shifty posted, and I had it in just fine with the factory air cleaner, just be sure to get the TBI one
Old Mar 10, 2004 | 06:09 PM
CaysE's Avatar
Just a thought... is that third mounting point sturdy? It looks like it's bolted into the lip of some sheet metal; I can't really tell. Has it ever cracked a windshield near that third mounting point?
Old Mar 10, 2004 | 06:13 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Look at how the windsheild is attached, I don't think it could crack it. That metal is also a little more sturdy then you would think.
Old Mar 10, 2004 | 06:23 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Yea what he said...The fire wall IS the strongest part of a third gen.
Old Mar 10, 2004 | 06:38 PM
CaysE's Avatar
I know I've heard somewhere that STBs with three points can crack a windshield. Maybe not on our cars then...
Old Mar 10, 2004 | 07:01 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Doesn't look like it to me, but it wouldn't be the first time ive been wrong.
Old Mar 10, 2004 | 08:07 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You are thinking about 4th gens. You won't find many 3pts there. The firewall is not quite as strong as ours. They made the frame a bit different to make that spot not absorb so much torsional loading like it does on a 3rd gen.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
