Passenger door Sagg
Old Mar 21, 2004 | 07:09 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Axle/Gears: Borg Warner
Passenger door Sagg
Help, My pass. Door is making the wind sound at high speeds and I smell stagnant water that seepped in via a car wash. I need to get the door aligned. The space between the fender and the door is pretty obvious. Any sugestions. Is that a job for a body shop?
Old Mar 24, 2004 | 02:16 AM
eInfoHost's Avatar
Hi,
Is the door shuting all the way? Does the door align right with the back of the body? Does the fender and hood align good?
If you are having problems with the door not shuting or door hard to shut then check to see if the upper hinge is bad. You can check the upper hinge by lifting up on the door and if it moves and the car doesn't you need to either replace the hinge or buy that hinge pin kit that andyz28 sells http://andyz28.com/3rdGen/ Those pins at autozone or others are just the lower pins and the lower pins don't fully support the wieght of the door. If this is your problem do a search on door sag.
Old Mar 24, 2004 | 09:45 PM
Parrydise7's Avatar
Be sure you check the price before buying. Prices vary wildly.
Old Mar 25, 2004 | 03:05 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Door alignment
Thanks for the info. My hood and fenders align perfectly. Both doors have a larger than normal gap at the fender. Just put on SFC's hope it's not too late. You can see pics at my web site. Already replaced the drivers side pin. Pass side does not seem to sag. It's just off somehow and water is getting in. Any way to re align the doors?
Old Mar 25, 2004 | 03:32 PM
eInfoHost's Avatar
Here's a thread that has some info on how to align the doors. It's the third post down. Hope this helps
https://www.thirdgen.org/techbb2/sho...ght=align+door
One more question: Does the door line up with the ground effects? Or does it leen more torwards the back? I hope that makes sense
Old Mar 30, 2004 | 12:32 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
Door SAg
One door is rubbing on the ground effects at the rear and one is not rubbing at all. Just that gap at the fenders looks like S&^%. Look at the web site to see for yourself.
Old Mar 30, 2004 | 12:50 PM
xxxman's Avatar
Car: 1987 IROC Z-28
Engine: 350 5.7
door pic
Check out the gap.
Old Mar 30, 2004 | 03:21 PM
eInfoHost's Avatar
Wierd....My last suggestion would be to try pushing the fenders back. Sorry, I coudn't be more helpful.
gta892000
Aug 11, 2019 11:16 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
m00n420
Sep 11, 2015 02:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Fronzizzle
Sep 8, 2015 12:10 PM
