replacement studs for strut mount retainers??
Old Mar 29, 2004 | 12:52 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Does any one know where I can get replacement studs for the strut mount retainers?? I original broke off a stud and got a new retainer from a junk yard, but now a stud off that one has broken and I'd like to replace with a stronger stud. The local hardware and parts store have been no help. Thanks!!
Old Apr 30, 2004 | 05:39 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Anyone??
Old Apr 30, 2004 | 09:37 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You talking about that C-shaped piece of metal that goes in the wheelwell? If so, I'd just drill out the stud hole and replace it with a Grade 8 bolt of your choice.
Ed
Old Apr 30, 2004 | 09:39 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I don't know exactly what the stud you're looking for looks like, but we use this place at work for all kinds of stuff:
http://www.mcmaster.com/
I'm changing strut mounts this weekend...hopefully the studs in mine will cooperate.
Old Apr 30, 2004 | 11:02 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
lots of people make the mistake of trying to force those bolts on, but if iirc they only need 18 ft lbs
Old May 5, 2004 | 03:16 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Yes ebmiller88, that is the part I am talking about. If I use a bolt, then I will have to have a sockets and both the nut and the bolt head under the fender well. I would like a stud like factory if possible.
I think the front end shop torqued the bolts correctly. They did not seem to hold the alignment well. Maybe to loose??
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
Old May 5, 2004 | 08:40 PM
ebmiller88's Avatar
You could always have the bolts tack welded to the plate, that will take care of the underneath socket issue.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
transaero
Aug 31, 2015 01:14 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
