Made an STB but did not notice a difference
Car: 85 Trans Am
Transmission: 700-R4
Ok, I made a 2 pt STB (will post pics tonight) and it did not make a noticible difference in hadling when I go around a hard courner at 60 mph
What EXACTLY does an STB do.
What EXACTLY does an STB do. Member
Car: 91 Z28
Engine: LB9
Transmission: auto
What other mods have you done to the front suspension to stiffen it up? If you just added a STB brace to a totally stock car then I doubt you'd notice much of a difference.
All the STB does is to stiffen the inner fenderwells and keep them from flexing. The 3 point STB is a better design than the 2 point because it triangulates the shocks towers with the firewall.
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I've put STB's on totally stock cars and notice an incredible difference. Everyone I know who has added one has noticed an equally incredible difference. I don't know what is up with yours.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Car: 85 Trans Am
Mabye I dont have enough bolts I Have one in each side. Or mabye my design is bad
I also used some pretty thin 1 in tubing (1/8) mabye that is letting it flex.
I also used some pretty thin 1 in tubing (1/8) mabye that is letting it flex. Last edited by ss85tadude; Apr 6, 2004 at 07:43 PM.
Car: '94 Corvette
It seems to me that a single two point bar is still going to alow flex, but at least it will flex with an equal distance
Another vote for trianglation...
Ron
Ron
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
here's a thought, maybe since you bent it like that then it became weaker and flexes. from the looks of it is looks like it will flex but it also looks like you did a good job on fabbing it up.
Car: '90 RS
Engine: 377 LSX
Originally posted by ss85tadude
So do you guys think one bolt on each side is good enough?
Car: 85 Trans Am
OK, I will add another bolt on each side this weekend. How much do the tower's actually flex? Is it inches or just fragments of inches?
Car: '90 RS
Engine: 377 LSX
Car: '86 T/A
Yes, my Jamex STB has 2 bolts. Add another bolt and you should be alright.
A couple of things that may help also. Put a lock nut on the bolts to prevent them from backing off. Also, preload the STB by jacking up the car from the k-member. Then tighten up the nuts and lower the car back down. That should have the stb preloaded, and makes a difference in the handling.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Yep, I put lock washers on. But if I preload the STB like you are saying, am I going to have to relocate my holes?
then you can try preloading it, then snug them down.
Car: 85 Trans Am
Here are some pics. And where is the K member (pics?) Sorry i am a newbie to suspension.
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Hey...yours looks almost identical to mine.
Its a 2-pt bar and has 2 bolts per side. Made an incredible diffference. I used 1" 12 guage also. Works great.
Its a 2-pt bar and has 2 bolts per side. Made an incredible diffference. I used 1" 12 guage also. Works great. Supreme Member
Car: 91 Camaro Vert
Originally posted by Dale
would round or square tubing be better in this application?
I've seen some of both, and just wondering.
square is easier to bend athome without a expencive bender.
either will work just as well in this app, but overall, round resists deflecting in every angle... while square only does in some.
It's most likely twisting. A vote for trianglation here.
Edit/add: I don't know what tires/condition you have, maybe they just don't generate enough grip to notice a seat of the pants feel.
Car: 85 Trans Am
Hey guy I finally tighened all the bolts (but did not pre-load) and it actually made a difference. It seems to be alot easier to handle in corners.
Thanks guys
Thanks guys
