Which will make my car handle better?
I either want to get rims this year , 17x9.5 all around, or i will get some new shocks and struts and sub frame connectors and a wonderbar.The shockes i was lookin at are hal 12 way adjustable ones for the rear , and i dont know what i get for the front. I really want something adjustable because i plan to autocross the car . I allready have some suspension stuff listed in the sig. Thanks.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Taking into account what you have in your sig, you really should get good shocks to go with your Eibachs. Then the 17"s with good, sticky tires.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Scour the junkyards for a GTA, Formula or IROC with the bigger front and rr sway bars, and take the bars and the mounts, and bolt them in. Yes, shocks/Struts (adjustable KYB's are good, too) and some bigger wheels and sticky tires.
Good luck
Troy
So Cal
Good luck
Troy
So Cal
Originally posted by nolanr0413
so what kind of struts should i get for the front. i like the hal shocks for the rear since they are adjustable.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have an 85 with ws6, or whatever they called the good suspension, so i dont think i need different sway bars.
sure you do. get these:
http://www.spohn.net/product.cfm?productid=1311
:lala: Trending Topics
If you're still running stock shocks/struts with lowering springs, they're probably toast. You definatly need to replace them before you even think about stuff like sway bars. I'm running Koni Sports (fronts are 5-way adjustable) and really like them. Just dont cheap out on dampers, since they're one of the most importent aspects of your suspension, especially if you're going to be autocrossing.
This is a quote from a book on autocross: "You want good shocks and you want them to be stiff...Don't go to Sears for this. Koni, Bilstein and Tokico all seem to be good choices."
As far as wheels, your tires matter alot more than your wheel size.
- Mike
- Mike
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
shocks and struts are a definite need. youll probably need mounts too. might as well get some poly bushing since the stock ones are prolly old and mushy. i dont know what years they used the 36mm/24mm sway bars, but those are a good, cheap upgrade if you can find them.
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
