4th to 3rd gen suspension parts.
Old Apr 11, 2004 | 07:11 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What suspension parts (if any) are interchangeable from a 4th gen? sway bars? Torque arms? Shocks, struts?LCA's? anything?
Old Apr 11, 2004 | 07:58 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
lca's and panhard for sure.
Old Apr 11, 2004 | 08:53 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
Rear shocks, sway bars, PH rod, LCA's, drive shaft, torque arm. The LS-1 drive shaft is shorter but works on the 88-89 and new 700's.
Basically if you had a 4th gen rear everything would bolt to it under the third gen it's the wheel spacing that is different and the brake brackets (I think).
I don't know but the gas tank may even interchange, I will know this in a couple of weeks.
Old Apr 11, 2004 | 11:46 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
everything in the back will, including the gas tank. torque arm too. i believe, you might wanna check, the driveshaft are will work for t-5s and 700s. 3rd gen rears are 4 in narrower, so 4th gen wheels wont directly bolt on, youd need spacers. nothing from the front will work though
Old Apr 14, 2004 | 11:00 PM
SWells's Avatar
Car: 83 Berlinetta
Engine: carbed 305
Transmission: 5 speed
the rear suspension is the same except the strut mounts....the top is different.
Old Apr 15, 2004 | 06:48 AM
gixxer92's Avatar
Engine: 7.0L, 6.2L
FYI, there are shocks in back. I didn't know they were didfferent. Nice to know.
Old Apr 15, 2004 | 12:27 PM
vjo90RS8's Avatar
Car: 2002 Z28
the KYB Gas-a-just shocks that i bought were from camaros 82-02, so im assuming at 3rd and 4th gens have the same shocks
Old Apr 15, 2004 | 12:36 PM
SWells's Avatar
Car: 83 Berlinetta
Engine: carbed 305
I've never tried the swap myself, the info is from the book "How to Tune & Modify Your Camaro 1982-1998" by Jason Scott. page 49 stated that the shocks & springs are different!!?? My apolpgies if the info is not accurate. Anyone ever tried the swap?
Old Apr 15, 2004 | 12:47 PM
vjo90RS8's Avatar
Car: 2002 Z28
maybe they were referring to the front suspension, i just looked at summit's website and their camaro shocks (KYB) are listed for 82-99, dont know if the 00 and up are any different. And the rear springs should be the same since you can use 3rd gen springs when swapping in a 4th gen rear.
Old Apr 15, 2004 | 12:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
everything suspension and driveline wise from the tailshaft back fit.
the driveshaft, TQ arm, rear LCAs, panhard, rear axle assembly including brakes, rear shocks, ect..
im running the following 4thgen parts right now:
LCAs
panhard
rear axle ( 3.42 posi with discs from 95 TA)
T56 (from 95 formula)
i have a 4thgen TQ arm, but its not in.
4thgen pedals. (i tweeked the gas pedal so i can heel-toe better)
hmm. list seemed longer when i started.. lol.
Old Apr 15, 2004 | 01:47 PM
SWells's Avatar
Car: 83 Berlinetta
Engine: carbed 305
Guys, I believe you and respect your knowledge. The book continues to say that the differences in the floor pan in the 4th gen created a need for a different shock than the 3rd gen. If you've done it and it works then my info is BS. Thanks for the education.
Old Apr 15, 2004 | 01:52 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lol thats because its really hard to make books change their minds...
yea, the shock mounting, length, and everything external are the same... the valving is probly slightly diffrent, but every model of shock has diffrent valving. the 4thgens are probly valved a little softer, but they still work fine.
also note, any 4thgen aftermarket shock works... including the adjustible ones...........
Old Apr 15, 2004 | 03:44 PM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
An LS1 driveshaft is exactly the same length as an LT1 and 84-92 3rd gen driveshaft. Some 82-83 driveshafts are the same length also.
Old Apr 15, 2004 | 09:28 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
I put a LS1 DS in my 94 the other day and the yoke for the input shaft is shorter I think, more here say on my behalf. I didn't compare before I stuck it in (hurried, by the will to want to drive the car). Anyone know if the yokes are different length? I know they will fit on the 87-88 and up trans.
Old Apr 16, 2004 | 04:51 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
They are the SAME length, I put one into a 97 Z28, and the shaft removed was the exact same length, along with the pile of 3rd gen ones i have, except the T10 one of course.
Old Apr 16, 2004 | 07:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
the seal on the T56 sticks out a little further and sits on a diffrent part of the yoke... so it looks like its diffrent but its not.. mechanicly, they're still connected in the same proper places.
donno if thats the answer you're looking for, but its just somthing i though i would throw in there...
Old Apr 16, 2004 | 06:03 PM
gixxer92's Avatar
Engine: 7.0L, 6.2L
It's all good information that I can relay.
Thank-you,
Tony
Old Jun 4, 2024 | 11:54 AM
Elwoodwrigley's Avatar
Re: 4th to 3rd gen suspension parts.
So to clarify- If I get an 2000 drive shaft out of a Camaro - aluminum- it will fit with no modification in my 1989 Formula Firebird
- 5.3 - 460le set up?
Old Jun 4, 2024 | 12:27 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As long as the trans is in the same place as stock and the 4L60 is the same dimensionally, you'll be fine.
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
