Prothane Total Kit
Old Apr 17, 2004 | 01:48 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
Prothane Total Kit
Does anyone know what exactly is in a Total Kit for the third gens? I suppose they leave out the sway bushings. Their site didn't lay it out very well.
Old Apr 17, 2004 | 02:14 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
Rear Lower Control Arm Bushings
Panhard Bar Bushings
Ball Joint Boots
Torque Arm Bushing
Tie Rod Boots
Front Sway Bar End Links
Front Sway Bar Bushings
Rear Sway Bar End Links
Rear Sway Bar Bushings
Transmission Mount
Front Control Arm Bushings
Old Apr 17, 2004 | 03:07 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hopefully better than what you get in the ES hyperflex kit.
Old Apr 17, 2004 | 03:15 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
Is this what they sent you?
What size sway bar bushings did they send?
If there is a choice, Summit doesn't list it anyway.
Old Apr 17, 2004 | 08:30 PM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
I don't think that is right. In addition to the sway bar bushings, which torque arm bushing did they send.
Old Apr 18, 2004 | 06:04 AM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
If you are looking for a "complete" kit, I would look into the Spohn kit. I picked one up last year and it had everything:
Torque arm bushing
trans mount
front LCA bushings
rear LCA bushings
PHR bushings
sway bar end links
sway bar bushings (upgraded to 36/24)
It is a really good kit and the price seems to be good on it, too.
Old Apr 18, 2004 | 07:26 AM
Breazlan's Avatar
Car: 88 Firebird
Engine: 302 SBC
I just took a look at the Spohn kit. Is that the Prothane kit or the Spohn version of the Prothane kit? You can select the sway bar and torque arm bushings on this kit, unlike what I was looking at on the Summit site. I am guessing that is why the Spohn kit is higher bucks, because you are adding to the standard Total Kit. Anyone know if I am assuming correctly?
Old Apr 21, 2004 | 05:57 PM
spatter1's Avatar
Car: 89 RS
Engine: LO3
I think that he puts together his own kits based on parts available. I got mine with the 36/24 swaybar bushings and I am not sure who made those bushings... but the front bar is greasable.
I thought it was the best kit going.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
