Spohn SFC's
Spohn SFC's
I'm going to order Spohn SFC's in the next day or two. I have a few questions. If I decide to get them coated for the extra 45 dollars is the black powercoated? It doesn't say. I have an LT1 with my 92 RS and in the future I'm going to install SLP 1 3/4" headers. Will these SFC's run me problems down the road? What has been your experience with getting SFC's coated from Spohn?
Brendon
Brendon
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Spohn SFC's
Brendon
Brendon
If you are going to go with new headers and exhaust, it would be my opinion to wait on SFC's. The powder coating is worthwhile, even if you grind small areas for the welds. I have both the SLP 1 3/4 headers and the Spohn SFC's (red powder coating). One installation problem with SFC's is the heat shield on the cat needs removed. But its your choice.
Car: '90 RS
Engine: 377 LSX
Why would you wait on headers? Thanks.
I said if you are going with new headers and exhaust, WAIT until that work is completed then install the SFC's. The case being installing the SFC's later will be easier.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
^^^^^^^^^^^^^^^^^^^ I'm with Apeiron.
...If you're pulling the exhaust anyway, install the SFCs while all that crap is out.
Ed
Ed
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
The guy i took in it had to cut up some part of the ypipe, and move around the exhaust to fit the Spohn Sub-Frames in. Wasnt a big deal, but in my case, i should of put the SFC in first then exhaust. And i should of not even coated it, cuz most of it had to be coming off to be welded. Doesnt matter cuz he black coated it for me after, so it worked out great.
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
im in same situation
i order comp eng sub frame connectors and they needed to be pass true the floor pan...and im maybe about to look for hotchkis one. or better ideas ?bbk ????spohn witch one???
big puzzle for stock exaust they all seems to be made only for dual staight exaust
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
darwinprice
17
Oct 11, 2015 11:51 PM
luvofjah
Sep 26, 2015 08:28 PM
