Where to get a four point roll bar?
Old Jun 17, 2004 | 05:17 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I've seen the one 84customZ has and it looks great, however its $249 + 100 some what dollars for shipping. Kind of ridiculous when spohn has a 8 point for only 149.99. That tells you some thing . Basically I want it to stiffen the chassis a bit and be able to run a four or five point harness without bolting the seat belts to the floor with my new racing seats. What other shops carry a four point bolt or weld in roll bar? Thanks.
Old Jun 17, 2004 | 09:09 PM
2out_The_Left's Avatar
i'd just get the 8 point and whatever you don't want in the car, don't weld in. just having the main brace behind your front seats won't do a thing for the chassy. you'll need the bars going to the trunk and the front floor boards to stiffen the car up. otherwise, on launches the car will still have the pull from the front on the chassy. the main brace will only come into play when going side to side (cornering) jeg's makes a cage that i bought and trimmed up to fit my notch. came out excellent actually.... i can post pictures if desired.
Old Jun 17, 2004 | 09:17 PM
pasky's Avatar
Thanks for the reply, I may do just that if there are no other options. I still want to look for a four point if possible, thanks.
Old Jun 17, 2004 | 10:21 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I don't know which bar you are talking about for 250 but does it bolt in? That may be why it costs more.
I put a 6 pt in my car years ago and it did wonders as far as tightening up the car. Also, my car has t-tops and it did alot to cure little creaks and rattles also. Not to mention it looks pretty cool!!! Chicks did it!
Old Jun 17, 2004 | 10:55 PM
pasky's Avatar
Yea its a bolt in. I never understand why them having to drill 16 holes into the roll bar warrants a $100 price increase....go figure
Old Jun 18, 2004 | 01:42 AM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
check Art Morrison:
http://www.google.com/catalogs?hl=en...519&catpage=39
Old Jun 18, 2004 | 01:54 AM
believe he's referring to this one:
https://www.thirdgen.org/techbb2/sho...hreadid=242793
Old Jun 18, 2004 | 02:08 AM
pasky's Avatar
Originally posted by Charlie's87
check Art Morrison:
Thanks a ton man, hell the chrome moly is only $40 more than that other roll bar.
Old Jun 18, 2004 | 09:48 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I was thinking about getting that autopower bar also, but I would have gotten it with the slanted bar and harness bar welded in. The reason why it is more expensive is because it is welded together already. The other NHRA style bars/cages are not welded at all, they are just a pile of bent pipes that you have to weld together. Sometimes you will have to cut and notch the bars too.
J-money
Jan 4, 2019 09:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Lanz06
Sep 14, 2015 07:16 PM
Fronzizzle
Sep 8, 2015 12:10 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
