Torque Arm Removal Problem
Old Jun 20, 2004 | 10:05 PM
Jim2_83TAs's Avatar
Car: 2 1983 Trans Ams
Engine: LU5 CFI / LG4 4BB
Transmission: 700R4 / Borg Warner T5
My Spohn torque arm has arrived but I cannot seem to get the 2 bolts on the old one that is still on my T/A off that is on the rear axle. I've been able to get the 2 bottom nuts off but the long bolts I can't budge. Has anyone else experienced this problem and if so, how have you gotten them off? I've sprayed penetrating oil on them numerous times and even tried an impact wrench and still can't get them to move. Should I try heating them up? If anyone has any suggestions, I'd really appreciate it.
Old Jun 20, 2004 | 10:13 PM
MikeS's Avatar
I thought that it was just two nut/bolt combos holding the rear of the torque arm on. After removing the two nuts, you can't just pull the bolts out?
Oh, have you taken the front of the torque arm loose yet?
Old Jun 20, 2004 | 10:15 PM
Jim2_83TAs's Avatar
Yes. I've already taken the front bracket off so the torque arm is free to move near the transmission.
Old Jun 20, 2004 | 10:26 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
if you cant get those long bolts to move use a hammer. also use some PBblaster it will loosen any rust in there.
Old Jun 20, 2004 | 10:34 PM
Jim2_83TAs's Avatar
PB Blaster is what I've been using on it and I have used a hammer on it too. But there's not too much room to hit it since I'm on the ground and so is the car. I'm going to try it again tomorrow. I've also tried a socket on it and a cheater bar and still can't get it to budge.
Old Jun 21, 2004 | 12:27 AM
MdFormula350's Avatar
i used like stated: pb blaster, a big hammer, and a big wrench on the bolt head. it helped for me to have someone else. one moved the old torque around and hit the bolt with a hammer, and i move the bolt with a wrench.
Old Jun 21, 2004 | 04:58 PM
Half-FastRacing's Avatar
Car: 89 IROC-Z
Engine: L98 - Stock
I just took my torque arm off as well. Get the rear as high as you can in order to move that hammer. In addition, use a punch (3/8" drive extension, or a screwdriver) to hit the bolt up once you get it flush with the torque arm. Worked for me, hopefully for you as well. - Adam
Old Jun 21, 2004 | 10:15 PM
Jim2_83TAs's Avatar
Thanks for all the suggestions guys. The hammer worked! The PB Blaster helped out alot too.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
3rdgenparts
Aug 8, 2015 07:09 PM
