loud creeking when i turn sharp
Old Sep 2, 2004 | 06:05 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
hey guys for as long as ive owned my car when ever i turn with the wheels at full lock in a direction i hear a creeking from the front end... what could this be? i know its somethign that has worn out with age but what is it right off so i know what to buy and have replaced? ball joints? thanx for the help guys... the car is up a little early for the winter due to hitting a deer and trahing my radiater, hood, driver side fender, head light bezil, and front clip is craked in two spots... i guess thats what you get when you are in a hurry and trying to get home doing 95 mph and then you hit a deer!
so i am rebuilding all the front end that was smashed and i remember that i herd that creekign when i was driving it before the deer insodent. lets just say i was very pissed about the deer cause it pushed my radiater support all the way back to the AC pump. but i got it all straitend back out by pulling it out with a polaris ranger:lala:
any way what should i buy to fix my creekign problem?
Old Sep 2, 2004 | 11:23 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
maybe belts
Old Sep 3, 2004 | 09:13 AM
z28monster's Avatar
Car: 86 IROC-Z
it could be but i think its soemthing more in the front end like somwthing worn out like ball joints or soemthing like that.... but i am putting new belts on it ill see what happens then.
Old Sep 3, 2004 | 02:36 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Belts? There's almost definitely a suspension problem. I have the same problem. Do a search on something like "cracking noise when turning," "creaking noise when turning," "noise when wheel turned to lock," or something along those lines.
I redid my entire front end (control arms, springs, struts, ball joints, control arm bushings, sway bar end links, and steering linkage), got and alignment, and I still have that noise.
When I did a little search, I found a few possibilities for the cause of the noise. (1) The bolts that hold the k-member to the body need to be tightened or replaced. (2) The steering stop point where the spindle hits the control arm needs to be greased. There are probably a few other ideas out there.
edit: Oh yeah, I just remembered another thing to check. Check for cracks where the steering box is bolted to the frame. Look into buying a wonderbar from TDS (see advertisment at the top of the page).
Old Sep 3, 2004 | 04:51 PM
z28monster's Avatar
Car: 86 IROC-Z
ok cool thanx for the info.... also yes i have herd of stress cracks happening over time around the steering box... say i do find soem how easy are these cracks to fix? and yes if i am lucky to not have any cracks i am still def going to by the brase any way they are only like 60 bucks any way. along with a strut tower brace and sub frame connecters.
also does any one by any chance have a pic of ware these stress cracks might be so i have a better idea of ware to look.
thanx for all the help in advance.
Old Sep 3, 2004 | 05:55 PM
I'm sure someone has done a repair job. I'll do a search.
edit: search results
https://www.thirdgen.org/techbb2/sho...threadid=83943
They keep talking about welding processes in this thread. Listen to the guys who say that mig/tig whatever are forms of arc welding. Someone keeps saying in this thread to use mig and not arc welding. MIG is a form of arc welding.
Also, if you can get a hold of a mag particle tester, it makes it really easy to find the cracks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Randomtask2
Sep 7, 2015 05:06 PM
tgp1990
Sep 4, 2015 06:24 AM
