rear end swap
Old Sep 6, 2004 | 05:38 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
rear end swap
installed my posi rear this weekend. Picked it up used for 100.
had my lca relocation brackets welded on and painted it all up. so far a rear easy swap installed my new spohns lca's and adjustable panhard bar. now i am just wainting for my shocks and springs to show up and the rear will be complete. with the exception of the brakes which are coming from baer. It is an easy swap and i would recomend it to any back yard mechanic.
anyone know the pinoin angle? should it be 0 i forget to check it before removal.
Jeff
Old Sep 6, 2004 | 05:39 PM
JeffW's Avatar
Engine: 305 tpi LB9
heres the goods installed on the car
Old Sep 6, 2004 | 05:40 PM
JeffW's Avatar
Engine: 305 tpi LB9
right side view
Old Sep 6, 2004 | 05:49 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
shoulda cleaned up the rear before installing it, other then that looks good
Old Sep 6, 2004 | 05:53 PM
JeffW's Avatar
Engine: 305 tpi LB9
clean what part? the rear was sanded down and painted and will get a por 15 treatment once it arrives. the backing plate for the brakes will be leaving with the baer replacement coming. what else is there?
Jeff
Old Sep 6, 2004 | 05:58 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ah your upgrading to baers, ok nvm then
Old Sep 6, 2004 | 11:14 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Jeff
What's the purpose of painting it and then POR-15'ing it? POR-15 has no effect if applied over paint. The advantage to POR-15 is that, with the MetalReady stuff, it chemically bonds to the metal...
Old Sep 6, 2004 | 11:16 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
whoa i completely missed it, yeah you basically wasted the por-15
Old Sep 7, 2004 | 01:47 AM
JeffW's Avatar
Engine: 305 tpi LB9
actuly if you check their web site thay say it is as good on bare metal as painted makes no diffrence whats so ever. i sprayed rustolium to keep it from rusting while i wait for the por to arrive.
the site is down or i'd grab it oh well... its in they faq.
Jeff
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
