ZR1 wheels... how to make them fit
Old Sep 10, 2004 | 11:19 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
i want to get ZR1 wheels for my 89 iroc, but the smallest offset they make is 35mm and in order for it to fit correctly, the offset needs to be 0-10mm offset, or it will sit way to far in, ive seen zr1's on thirdgens, how do you guys make them fit? a spacer would help a little bit, but a 30mm spacers is just insane, the lugs wouldnt even go on.
Old Sep 11, 2004 | 07:59 AM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
http://www.skulte.com/adapters.html
Old Sep 11, 2004 | 08:47 PM
QuickStyle's Avatar
Car: 91 Z28
awesome, so do you think i should go with 275/40/17 ? or would i be able to go any wider cuz the adapters will allow more? bcuz you gotta have the widest tire.
Old Sep 11, 2004 | 10:07 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
SLP makes a ZR1 rim that fits thirdgens without adapters. The only problem is the size, they are 17 x 8. Most people want the wider 9 or 9.5 rims.
Old Sep 12, 2004 | 05:40 PM
Marc 85Z28's Avatar
275/40r17 will fit fine on all 4 corners, without rubbing. You can also run 285/40r17 in the rear without problems.
Old Sep 12, 2004 | 06:26 PM
QuickStyle's Avatar
Car: 91 Z28
should i get 17x11 in rear and 17x9 in front, or 17x9 all around, i would prefer the 11's in the back but i dont know if they would fit
Old Sep 12, 2004 | 10:10 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Heres another site that sells em. I think they may be cheaper too. This is where I bought mine from.
http://members.***.net/completevalue....html#Shipping
Old Sep 12, 2004 | 11:26 PM
QuickStyle's Avatar
Car: 91 Z28
im not worried about the price of the adapters, i work for americas tire company, so i get a discount and them, im just worried if the 11's would fit in the back or not with the adapters
Old Sep 13, 2004 | 05:16 PM
Marc 85Z28's Avatar
Could you put 17x11s in the rear? Sure. Should you? That's not as easy an answer. Its more expensive for one. Second, its a very tight fit, and requires extensive massaging of the rear wheelwells. Third, you'll need to replace most of the rear suspension. Stock parts are very flexible. Since clearances are so tight with 17x11s, any movement could be disastrous. Fourth, 275/40r17 tires are MUCH easier to come by than a 315/35r17 that you would put on a 17x11. One blowout and your screwed.
I vote for 17x9s all around.
BTW- dont cheap out on the adapters. They are not all created equal. As usual, you get what you pay for. I've heard stories of other brand adapters breaking. I bought mine from Skulte. I've had them nearly 3 years with no problems, and I've never heard a single complaint about them, anywhere.
Old Sep 14, 2004 | 12:56 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
i bought my adapters from fbodymotorssports never had a problem either but i have 1.5 rear and 2" spacers front and 17*9.5 zr1 all around with the 36 mm offset
Old Sep 14, 2004 | 03:40 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
Do you need spacers front and back or are they just for the front.
Old Sep 14, 2004 | 04:56 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
front and back
Old Sep 14, 2004 | 09:48 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
There is nothing wrong with the spacers I posted. There are machined billet aluminum just like skulte's. They are some beefy suckers I know that. He sells em like crazy on ebay. The guy lives like 20 mins from me. I am pretty sure he makes them himself. I checked up on them before I bought them and didnt see anything wrong with them at all. And you cant beat about $100 cheaper. Just my thoughts.
Old Sep 15, 2004 | 11:33 AM
Marc 85Z28's Avatar
While all that may be true, I'd again like to state that Skulte's adapters have an excellent reputation, and have been proven time and time again. Those ebay units have not. Personally, I would not trust adapters that were that much cheaper. Like anything else, you get what you pay for.
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
kyle5647
Aug 15, 2015 11:56 PM
matthew911
Aug 12, 2015 09:38 AM
z28addict8490
Aug 7, 2015 08:48 PM
