i need a tip: why wont anyone answer my question
Car: 86 Camaro
Engine: 350: vortec heads, lt1 block
Transmission: TH700R4: Mr. Shift kit
i just want someone to help. im trying to decide what im going to do but i need some help to figure out what to do. can adjustable springs help the car handle better if it has drag springs?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The only way to have adjustable springs are to have a complete front and rear coil over conversion with the ride height adjustability. I assume you mean adjustable shocks. Adjustable shocks can help greatly at the track if your car is set-up to actually take advantage of them. In addtion I do beleive that their opposite settings could help control the drag springs for normal driving.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Ed
Car: 86 Camaro
i dont mean adjustable springs, i f'ed up (adjustable shocks). i know you cant exactly have both but you can make up for it a little. so youre saying that adjustable struts/shocks wont help it handle better by changing the settings with drag springs? i find that hard to believe. i know it wont handle great, but i think it should help a little.
i got a little thrown off by the second comment, so read my next post for a reply to the first comment. i couldn't delete this post for some reason
Car: 86 Camaro
Car: '90 RS
Engine: 377 LSX
Originally posted by pwmin
thank you. thats all i needed to know. i wanted to confirm what i thought.
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Drag shocks have very lower rebound damper, and very high bump damper. Typical drag shock is 90% bump/10%rebound.
Your average roadrace shock is more like 40/60 or 40% bump/ 60% rebound forces.
There is no shock that will single dial both of these forces to different values. The adjustment will increase or decrease both proportionately ALWAYS retaining the 40/60 proportion. Low setting may be valved at say 40lbspressure on bump/60lbs pressure on rebound and then highest setting may be more like 80lbs bump/120lbs rebound.
If you want the ability to change bump and rebound proportions, You will need to buy dual adjustment struts $$$$$$$. You'll need separate bump and rebound adjusters.
Car: 86 Camaro
it is mostly going to be for at the strip, but i wanted to be able to mediate for this a little if i take it out on the street. im not looking to have both. thanks for the help. im really close to deciding what i wanted to do, i just needed a little more input
